VuDuo: How to configure Double Tuners ?
Charly Brown
Hi there !
I've got a problem to record and watch different channels on same satellite due to the fact
that Tuner B will be able for recording but I can only watch other channels available on
same transponders...
Do you guys know how to help me getting the good configuration of both tuners ?
I have Tuner A configured as Simple with ports for the three satellites that I use (A/Hispasat
30.0W, 2/Astra 19.2E, 3/nothing connected and 4/Hotbird 13.0E and Tuner B=Equal Tuner A.
Many thanks in advance for your help and know how !
you need a dual out lnb (2 connectors if you use that lnb just for one duo) for use the 2 different tuner
did yours lnbs has the dual out?
Two connectors at one LNB means TWO cables connected to receiver and of course two diSeq switches. Do you have this hardware configuration?
@Charly Brown
You need:
- two output on all LNBs (2 on 30W, 2 on 13E and 2 on 19.2 E
- two DiSEqC switches
you must connect the cables that are coming out from DiSEqC to the Tuners A and B on the box
if you use usually just one sat position, you can change as well just the most used one with a twin output lnb (one wire connected as the previous one and the other wire to the tunerB input ;) )
if you cannot add wires: give a look to the expensive scr unicable lnb and its switch
