vuduo request for assistance
angelo gomes
Hello
afterflashingwiththeblackhole1.7.0bm750fullusbIstartsandremainslongonloadingdefaultsometimesI getaset upsomemenubutattherebootitagainandstillagainonloading default
Thank youforyouraid
Hello
Thank youforyouraid
First try using spaces ;). I suggest try reflash box again. Remove all usb from back of machine.
Does he need to update the boot loader too angelofsky? I'm unsure of from which image this needs to be done from.
I think no because it's needed to flash images newer than 1.6.6. If the user has at least 1.6.7 on flash there is no problem at all.
Hithanksyou for manyahelp meandIthank verymuchIamFrenchandI have a lotofdifficultyworkingwithgoogletranslatorbutinfrancenosolutionIwilltrytogiveanewimage of BHandIwantyoutothe run
Manythanksforthetime
Hithanksyou for manyahelp meandIthank very much IamFrenchandI have a lotof difficult yworking with google translator butin france no solution Iwill try to give a new image of BH and I want you tothe run
Many thanks for the time
Hello
I return to you because on the French section it na no answer is the desert
My vuduo just start with the 1.7.0 bm 750 full usb everything is ok could you tell me a flashed more recent pou replace the 1.7.0 bm 750 full usb
Thank you very much
Yes I'm looking for an image more recent than the 1.7.0 is 2011 but I want to know if I can put it on mine vuduo V2 without danger of blocking?
Thank you for your help
