Vuo2 LCD screen stuck on Vu+ Duo2
Contact99
This morning I turned my Duo2 on and have noticed that the LCD Screen is stuck on Vu+Duo2 with all the stripped colors. I possible might have accidentally touched something As before It showed all the Details of what channel you were watching. Can a member please tell me where I can change it back. (Black Hole 2.1.0)
Thanks
If your Duo2 is still working (not stuck on boot) check LCD4linux plugin configuration.
Another solution might be to make a personal backup (or manually save your settings) and then install 2.1.1 followed by a setting restore.
Thanks for that, the Duo2 is working ok its only the LCD screen that somehow found itself disabled. I enabled it via that Plugin, It has the standard black screen and has ONLY the channel name in the LCD up the top. There are heaps of setting to touch in that plugin but don't want to play with them until I understand a little more about them. Can you please give me a hint on what to turn on to fill the LCD screen just for the moment as it looks a little Odd just with the small Channel name up the top. This possibly defaulted after I was playing with Hbb TV as it was about that minute that the LCD screen Disappeared.
I hope to update my BH image after If we are lucky a fix for the Hbb Tv that is not working correctly so we can use our new service in Oz for freeView Plus.
When I disabled the Browser with Hbb TV as it did not work I must have deleted it as its not in the Plugins list anymore
I tried about 5 off them and all are very good. Its pity that so far I have not found to many picons to suit our satellites in our region
