vuplus duo4k unknown wireless network interface problem
Johnessen
I have been having this problem "unknown wireless network interface problem"on Duo 4k with Openblackhole firmawre version 4.2.045.(Wlan Connection) I reflashed it to Vti image, this problem didn´t exist but back to Openblackhole it cames back. But with lan cable everythings works fine. What can be the problem?
Does the Duo 4K have a built in Wi Fi connection, or are you using a USB wireless adapter?
It sounds like it might be a driver issue.
Was it working when you flashed Open Black Hole, and set up the WLAN option, before updating?
it didn´t work when i first flashed obh, i thought maybe the network driver was missing, i used lan connection to update, still no wlan coonection, i tried flashing vti image, it worked. I flashed obh firmware back, had the same problem.
I have obh on my duo2 without any problem again but just upgraded to duo 4k and since I have been using obh firmware for years now decided to continue with it. Maybe I just tried tried openpli firmware, it worked at first configuation.
Later in the da when I get home I will try normal BH firmware and post result
