vusolo4k openblackhole
ciccio17
hi, i have last openblackhole on my solo4k, i have a strange problem with network. i use the internal wifi chipset . the box is connected to internet, but i can't access to ftp,telnet,ssh,and even the ping is not working. i have tried to set dhcp,static ip address, but nothing change. how i can solve this annoying problem please.
i'm not sure but i think i solved the problem. i'm coming from openatv, and i think the new flash cancelled the box password, now i set the password and a static ip, for now is working ok, i ll let you know if this is correct.
the problem still here i just can't believe, i don't know how to solve this. now is even worst. so i'm the only one with this problem?
i'm now using a usb atheros tplink chipset so now for sure i ll understand if the problem is ralink driver or not. i'll let you know.
my final test is done. the ralink chipset is totally garbage. not problem at all with usb atheros-htc chipset. the bad think is that is an expansive box and the internal wifi is unusable. I have also tried other images and the problem is on all. hope vuplus will get this message.
These are boxes who do a hard work, in terms of data sent and received. My advice is to solve any problem using powerlines. Your life will change! ;)
I finally figured out the problem. The problem seems to be the fact that this chipset does not work well with WPA2 PSK CCMP encryption. So for everyone who has my same problem, the solution is to use WPA. Now it works perfectly.
