VuZero and triplefeed
3iondo
Hi all,
i'm wondering if the VuZero (blackhole 3.0.1F) can support a triplefeed's LNB or just a DualFeed.
It has DiSEqC 2.1 so i think it can but ... i have to be sure before buy an useless thing.
Thanks.
Thanks for reply
I'm oriented on Inverto (this model gets 13E/16E/19.2E)
but if someone has a working config, i'm open to changes ...
Just a question: is it possible to get 9.0E/13E/19.2E with a Single Triple Feed ?
Or do i have to get something like that
Thanks for your time and knowledge.
Inverto makes many different lnb, so I do not know exactly which one you are wanting to use. Your question would probably be best answered by the person you are buying the Inverto lnb from.
Any triple lnb can be a challenge to setup on a dish, so be sure to ask the lnb seller about that and make sure the dish you have will support a triple lnb.
The Zero receiver should be able to support most types of Inverto lnbs, but again, check with the lnb seller before buying!
"Last edited by a moderator: Today at 12:36 PM"
Sorry about posted links ...
but it was necessary to show what i was talk about !
MODERATORS:
Is there a LNB's compatibility/configuration thread or subforum ?
el bandido thank you, for me it's enough to know that Zero supports 3ple feed.
Cheers
