vuzero help
In obh is menu to reset pasword by remonte countrole.
In BH i think only reflash help.
Good way is create alvays backup on usb or have all importend cfg/file/pasword on external usb or driver
Yes.
You can back up your channels, and bouquets, using dreamboxedit.
Yes is possible used personabackup in menu image too.
But i think he no backup all personall cfg.
Forget pasword is real problem to alot people.
If you used OBH you find menu to change password by remote countrole this way is very usfull in alot problems.
