Vuzero WiFi RT5370 problem
pennym
My wifi dongle (ls code 148f:5370) works perfectly with original factory image with my vuzero.
I cannot for the life of me get it to work with this image from your forum
' BlackHole-3.0.1-vuzero_usb_release_20151124_bfd6ded '
I am using the wireless LAN setup in system menu.
The dongle is found - It detects my network - The network AP is correct - The WPA key is correct, but always fails Network test with ' Wireless Network - disconnected '.
Any help would be appreciated as it is sending me nuts and I was really wanting to use the Blackhole image.
Resolved
I installed the Wireless Lan Plugin - It installed 7 packages including python updates.
It seems I was trying to connect using WPA when in fact it should have been WPA2. The original image did connect using the WPA setting.
Hope this helps someone else.
