Hi.
I have a Vu+ DUO in my house and at my summer residence. I would like to access the VU+ internal harddrive at home from the box at the summer residence.
So i did a port forwarding in my home router, port 445 to the local static IP og the box.
At the box in the summer residence i did following setup:
Local share name: Home
Mount type: CIFS share
Server IP: WAN IP @ home
Server share: /media/hdd/movie
Use as HDD replacement: No
Mount options: rw
Username: root
Password: ********
I can se the folder "Home" in /media/net/Home - but the folder is empty. In Mounts editor, there is a red cross at the globe, so there is clearny no connectivity :-(
I did try to mount on my windows 7 PC....
\\local IP\Root\media\hdd\movie - works just fine
\\local IP\Harddisk\movie - works just fine
\\WAN IP\Root\media\hdd\movie - Does not work, is does not accept login credentials
\\WAN IP\Harddisk\movie - Does not work, is does not accept login credentials
Maybe my port forwarding is wrong ?
Can someone help me, thanks
Mount options: rw
Username: root
Password: ********
