want to upgrade BH 2.0.9 to 3.1.0 on my solo need help!
juancameron
Hi
have BH 2.0.9 on my solo I installed it like six years ago i need to upgrade it to latest version 3.1.0 should i just put it on a fat32 flash and upgrade it or do i need to do something first? I mean bootloder or something?
tanks
Try and flash: I don't think a new bootloader is needed but, in case, flashing won't succeed...
Maybe you want to save at least your channels (settings) by a software or the OWIF itself, just to save time.
Also, if your tuner configuration is complex, you should take note of it.
