web browser for BH 2.0.5
Install HbbTV from BH SpeedUp. Opera Browser is included.
PS: Upgrade to BH 2.0.6 and do an online update to Rev. C
Can I ask is there a lot do differences between 205 and 206? If not am I not aswell just staying where i am?
Thanks
Hi
Just installed hbbtv and after installed I got the green error screen, so not sure it's installed, where would hbbtv be if it was installed properly? In plugins?
Thanks
Model of box? You have to have SWAP enabled for Solo/Duo. And also free flash for installing HbbTV.
Hi
Thanks
Hi, sidTM. I have tried the same thing as you a few days ago. After paolino's instruction, I can use the web-browser Opera without any problem. My DUO2 runs BH2.0.6.
Goto menu >setup >speedup > activated HbbTV; Then go to the plugin menu, you will find the Opera Webbrowser in there.
Hey
Yea I have a duo but as I said when enabling the hbbtv from the speed it seems to go through the installation ok but when enigma restarts I get the green screen and hbbtv doesn't install,
Paolino I. Will try enabling SWAP and free flash, as these in the speed up option aswell?
Hey
You have to have as much flash free as possible. Remove all plugins and skins not in use. HbbTV and Opera are "flash and RAM eaters".
