web-x-tv
axel2906
Hi all,
I don't know if i'm in the good section...
I would like to know if it is possible to view a channel on the tv and another one with web-x-tv.
So my wife want to see channel 1 on the tv and i want to see the channel 2 om my computer.
Thank's
Hi all,
Thank's
Yes, it's possible.
You only need to select a channel in WebTv window.
thank's for the answer, normally i must buy the Vu+ Duo but i want to be sure before buy it.
thank's for this pretty community
Remember you need two LNB and two antenna cable or a LNB unicable to watch channel broadcasted on different transponders.
If you have only an LNB you will be able to watch only two different channel broadcasted on the same transponder.
I know that ;-)
I wasn't sure that web-x-tv can stream an another channel that the TV. For me the webx stream only the channel that is viewing on the tv.
I try with one tuner (with my dm600) to watch two differents channel on the same transponder (channel 1 on tv and channel 2 with web-x) and it doesn't work. So it's why i ask this.
Thank's
