webif issue
netguy
hi guys running vu-duo2 with obh latest version the problem is when i wanna use webif on my pc and open a stream with vlc the box crashes then when box reboots and i try again it works opens the stream then when i wanna change stream crashes any help cheers
If it crashes, you must have a crash log on:
/home/root/logs
/media/hdd
/media/usb
It depends if you set anything in "logs manager".
No "crashlog" ... "no help"!.
