WebIf Manual Timer - No Channels Showing
mrkrabs
Hi guys,
I've had a very annoying issue for some time now which and I really should have asked this long ago. Basically I am unable to create a manual timer in WebIf or on any mobile app because for some reason the channel list shows as 'Nothing'. The dropdown list is empty. See screenshot below. I can't select a channel to record. I used to use this feature a lot. I am not sure if this is a bug with BH 3.0.1.0 but would be great if someone knows how to fix it. Thank you.
Brand: Vu+
Model: Solo²
Chipset: 7356
Frontprocessor Version: 0
Total Memory: 573072 kB
Free Memory: 330364 kB
Box Uptime: 12d 16:38
System OE: 3.0
Distro: BlackHole
Firmware version: 3.0.1.0
Driver date: N/A
Kernel version: 3.13.5
Gui version: 2016-01-19-master
Thanks. I thought I was on the latest version already but clearly not! I'm confident this will solve the problem :-)
