WebIF title problem ;)
Persian Prince
hi dear Black Hole team
i think you should check WebIF title ;)
it's "Dreambox WebControl" not "VuPlus WebControl" (checked with FireFox 7.0.1)
no need to mention but you are the best
Dear BlackHole team,
1- When no picon installed , it shows "dreambox" instead. (VUPLUS UNO)
2-In some menu windows, it shows PVR button. As you know, UNO has "R" button to show archive or recorded movies.
3- when connect via DCC v1.41, the program does not recognize Vuplus UNO. It shows: "Enigma2 detected (Boxtype unknown)". Any solution? Please.
Thanks for your great efforts. As Persian Prince mentioned, no need to say, u r the best.
What skin are you using?
This is how DCC works there is no detection fot other e2 devices. This is one fot BernyR to change.
Sent from my GT-I9000 using Tapatalk
