rafal1509 Vu+ Newbie Mar 25, 2014 #1 hello how to upgrade webif in solo2 at the moment ver. is 0.2.7 i need 1.2 i think or higher anyway , please for help
angelofsky1980 BlackHole Driver Specialist Mar 25, 2014 #2 rafal1509 said: hello how to upgrade webif in solo2 at the moment ver. is 0.2.7 i need 1.2 i think or higher anyway , please for help Click to expand... You can update OpenWebif by hand downloading the updated file from E2OpenPlugins webpage
rafal1509 Vu+ Newbie Mar 27, 2014 #3 angelofsky1980 said: You can update OpenWebif by hand downloading the updated file from E2OpenPlugins webpage Click to expand... thank, if you can say how to change that will be greate, because i change local and plugin in my solo2 but still have same ver thank you
