WebradioFS 2.2 (for mp3 streams)
Matrix10
Readme INFO
Unfortunately historically been a collection of stream Shoutcast no longer possible (and will for the foreseeable future be)
Therefore, there is webradioFS now in a new version:
- several favorite files possible
- to change a favorite right in the plugin (eg changed URL)
- Add new favorites directly in the plugin
- errors are handled better
- Skins aged (for Skinner)
- Language Support
favorites:
the Favorites files are located in ‘ /etc/ConfFS/ ‘ and must necessarily have the extension ‘. wbrFS_fav’ . It can be used more than one favorite files (example: 1_Micha.wbrFS_fav / 2_Klaus.wbrFS_fav / 3_Ines.wbrFS_fav / 4_Reaggy.wbrFS_fav / 5_Oldies.wbrFS_fav) The numbering is useful because the favorites are ordered alphabetically, starting from the first stream is always File loaded.
The favorite files (do not use DOS / Windows mode!) with an editor to edit.
The individual streams are registered as follows:
[Native Radio (Mixed Format)]
url = http://camstreaming.brownrice.com:10501
description = Bit rate: 128, Indian Music
!! who has already been used and would use his favorite webradio further, needs to adapt and move the Favorites file in the directory ‘/etc/ConfFS/ “
Operation:
faster exchange Favorites: Bouquet buttons
Favorites list: yellow
selected Edit Favorites: blue
Settings: red
Sleep-Timer: green
Also buttons: Menu, Help, Info
Thanks to author @shadowrider
For info you can add your streams URLs with Linux editor in
/etc/ConfFS/sample.wbrFS_fav
or you make new favorites files with the same extension wbrFS_fav
Read Info.
Use only working URLs to avoid a drop/bug in plugin
You can download plugin from our image server.
Now looking for a good "sample.wbrFS_fav" file
