WebradioFS, how to edit favoriten with pc
Tecko
How can I edit webradioFS_favs.db on my pc. I tried SQllite editor but that isn't user friendly. Is there an other way to edit this file?
I was used to edit favorites from shoutcast in wordpad or notepad.
I do not know how to edit the database file, but if you use an enigma2 receiver (I believe you are), you may try the deambox edit. It is very easy to use and you can edit channel list, radiolist, IPTV list... It is a Microsoft window software.
Have you tried that, or guessing ????
sqlite DB format in dreamboxedit,
@Tecko perhaps try SQLite Database Browser 2.0 b1.exe
you can also edit in pluginmenu's don't remember about create record.
aren't logo's in the stream (or from website) atleast I thought so because screensaver/logos changes for me on same stream
I.m back to shoutcast much easier to edit. webradioFS giving stream errors on the ones I did edit. That wasn't the case before.
OK
one other thing, which box do you have.
DUO2 or something with Lcd4Linux (external display)
then you can integrate L4L and webradioFS :)
like one of mine then,
you can than install plugin lcd4linux (existing thread on this forum)
and configure and connect an android tablet and show webradioFS on that as well as EPG, weather, and loads of other things.
