WebRadioFS streaming problem
komodo
Hi,
i have latest BH and latest WebradioFS plugin, and there i have problem playing most of the streams.
I have discussed this issue with autor of the plugin, and he told me, that problem will be in the image.
So, when i try to play streams for example from Trance genre, for most of them i can see
Trying to establish connection.
Only one stream is working and this is di.fm.
Is there any way to find where can the problem be, or can anyone confirm this issue ?
Last time, with BH 2.0.3, there was no problem with this plugin, so maybe something is missing, but there is no log.
Thank you
Martin
What about your internet connection ?
I have used WebradioFS and Blackhole for ages without problem, 100% compatible.
But noway I can test everything in trance
try below instead in a new or existing bouquet in your STB.
to test your internet connection and exclude the plugin
low, normal and high quality (bandwidth) (NB could be geolocked)
#NAME IP_Radio
#SERVICE 4097:0:2:0:0:0:0:0:0:0:rtsp%3a//mobil-live.sr.se/mobilradio/kanaler/p4gavleborg-aac-32:P4 OK 3gp rtsp low
#DESCRIPTION P4 OK 3gp rtsp low
#SERVICE 4097:0:2:0:0:0:0:0:0:0:rtsp%3a//mobil-live.sr.se/mobilradio/kanaler/p4gavleborg-aac-96:P4 OK 3gp rtsp normal
#DESCRIPTION P4 OK 3gp rtsp normal
#SERVICE 4097:0:2:0:0:0:0:0:0:0:rtsp%3a//mobil-live.sr.se/mobilradio/kanaler/p4gavleborg-aac-192:P4 OK 3gp rtsp high
#DESCRIPTION P4 OK 3gp rtsp high
#NAME IP_Radio
Hi, connection is not a problem, i can play streams in media player in pc (Clementine player) without problem, and i have 60/10Mbit.
As i said, some streams playing well, but most not, for example 16bit, Armin van Buuren, di.fm, Divbyzero are ok, but ah.fm, 1mix radio, A state of trance not, and there is only Trying to establish connection.
So i don't understand where could be the problem.
Is there any debug mode, where i can see what is this plugin doing ?
Yes, for me that perhaps proves that your ISP is OK
but what about your STB's internet connection ???
(e.g switchport, cable, STB-NIC or what ever)
for me: ah.fm and 1mix radio OK,
A state of trance NOK complete silence, not troubleshouted by me.
tried a moment ago with Solo2 with 2072 and with many services and devices such as L4L and ambilight......,
internet throughput measured approx 30/30 and STB is connected with cable !!!
tried my 4097 examples ?? or something else from your STB to continue troubleshouting with your internet connection from STB
ISP is ok, net is ok :-) i'm sure. I am network admin, so those things are first ;-)
How do you measure net throughput on VU+ ?
So what should i try to reach this problem ?
Have not measured troughput at/on STB, no problems there :-)
only measured in router and laptop and tablets/phones.
Out of ideas then, perhaps try 203 again and test if it's still functional,
after backup of running enviroment, or perhaps try youtube with highquality.
BTW was kinda hard work for me to get >version than 205 to work,
but now on 2072 with a little hands on delay's and restart's of service,
to get my USB DVB-T2 to work (usbdevices you know), but no problem with WebradioFS
Have not measured troughput at/on STB, no problems there :)
Ok man, i'll try 203 and i will see if it's working.
Ok, so i tried to install 2.0.3 but there was problem installing WebradioFS, so i install fresh 2.0.7 and all streams are ok.
Next i'v restored my image from backup and remove /etc/enigma2/settings file, and all streams ar ok.
So now i don't know where the problem is, but for sure, is some option in settings file. I copied settings from image to image a long time ago, so maybe something has changed in BH.
Anyway this fixed my problem, and if i determine which setting does this, i will report.
Thanks for your help.
