Matrix10
After several days of testing
I have to recommend this fantastic network hard disk.
What's not so expensive
I have the 1TB version, which cost me about 115 euro including local postage.
It supports CIFS and recording is going fantastically good with all VU boxis
Installation is very simple with NetworkBrowser CIFS .
And after with Recording paths / Select locations
On the HDD is already folder /public/movie
where after installing it is possible to directly record.
Box awakens from standby without any problems.
If you have the HDD do not forget to do a firmware update
directly during the first installation.
On HDD, of course, can connect all network users.
Supports, backup and mobile connections
More at the manufacturer site.
http://www.wdc.com/en/products/products.aspx?id=280
