What does the Network Scan?
roverdublin
Hi,
When I do the MANUAL SEARCH on my VU+Duo2 I can choose to use the NETWORK SCAN.
What is this actually doing?
Thanks
Hi,
Thanks
Network Scan mean that the box analyze the "Network ID" into Transpodners and search all the TPs associated with the "Network". For example it's an usual configuration for broadcasters to "link" their TPs into a "Network of TPs" so you should can scan all the TPs of a broadcaster starting from a single frequency.
I hope to have answered in a clear way
Thanks for the fast answer. I am not quite sure if I got it.
What benefit is that to me?
I assume this is not the Bouquet?
Can I see all transponders within a NETWORK ones the Search is over?
Do a network scan each time,and play what you see/want...lol
