What don't work in OBH!
fackeritza
Unfortunately this things don't work:
1. HDMI CEC ( When start TV ( Tested on Panasonic ) it starts in DVB-C and not in HDMI )
2. EPG NEXT EVENTS ( you have to select EPG and after Yellow to see next events instead of only EPG button to see next events )
Untill these will be fixed will use BH 2.1.6.
Any solution ?
Any solution ?
Strange
I have Epg Next in Epg (epg button) on the right side of the panel
I don't want only next event. I want to see next events ( for all day ). In BH216 it shows events for all day ( using cross epg ofc ). Hdmi cec works for u ?
next events ( for all day ) such a thing does not exist in EventView (epg button)
In the Open Black Hole image is the same as in Black Hole image there is no difference.
I have not use and test HDMI CEC . I think there are differences.
But no matter what
you'll never be able to have all the same opportunities in both images.
They differ.
If this is possible then we would have only one image.
HDMI CeC not work for me because there no option for home theatre and some device doesn't start on properly source.
Only one CeC plugin fully working for me is on original black Hole images.
@Matrix10
It's possible to use the original BH HDMI CeC plugin on OBH image,if yes where download it?
Thanks in advance.
OBH 0.6
HDMI-CEC is still not working as expected
Vu+Box can wakeUp TV but TVinput(AV / Hdmi) is not changed correctly.
