What dual band (2.4Ghz - 5Ghz) USB dongle is the best choice for Vu+ Duo?
DS-1
Hi guys,
I've just bought a 5Ghz WIFI modem/router to solve a problem I have with 2.4Ghz audio/video sender.
Obviously now my wifi dongle I used for Vu+ Duo won't work anymore.
What USB WIFI dual band dongle chipset can I buy to have a 100% compatibility with my Duo?
Thanks in advance for the reply!
Don't use a wifi dongle, but buy a wireless bridge, much more versatile and powerful, and with no compatibility problems.;)
Thanks for the reply.
I prefer to use USB wifi dongle first because I think the price would be lower!
Nope, wrong assumption...
Price may be lower or comparable, efficiency and transmission power much better than a small wifi dongle (not to mention possible problems trying to correctly configure a dual band dongle through Enigma2)...:)
Can be used for up to 4 devices at the same time (TV, bluray player, mediaplayer, etc.)
Single band 5 GHz:
http://www.amazon.com/Linksys-Wireless-AC-Universal-Connector-WUMC710/dp/B0090DX8O8/ref=sr_1_12?ie=UTF8&qid=1416231746&sr=8-12
Dual band 2.4 and 5 GHz:
http://www.amazon.com/Belkin-Universal-Port-HDTV-Wireless/dp/B005O88CY4/ref=sr_1_20?ie=UTF8&qid=1416232142&sr=8-20
http://www.amazon.com/Bridge-4-Port-Gigabit-Speeds-Wireless/dp/B00A66WJWK/ref=pd_cp_pc_0
Thanks a lot for the links.
Now I use a 2.4Ghz dongle and for my everyday use it's perfect: I use wifi for Vu+ only for FTP and to update channel list. That's why I prefer to but a dongle.
Is it that hard to configure and use a 5Ghz dongle on Vu+ Duo?
Generally speaking, a dual band device needs 2 completely separate wireless configuration settings (SSID, security, preshared key, WMM, etc.), one for the 2.4 GHz band and one for the 5 GHz band.
Therefore also the configuration interface shown on the screen should provide 2 separate sets of configuration options. Are those 2 sets available in Enigma 2? I don't know, I've never tested such situation.
