Request What is the best b/hole for duo?
birdman99
I have been using 1.7.2 for my duo for some time now with good results.#
I have tryed newer versions but always have problems and find the older version to be more reliable for my use.
I do feel ignorant though and am concerned that i dont get the max from my duo.
Anyone got any suggestions??
I think best to used is alvays last version becouse have solved bugs finded in older version image .
This bugs solved VU+ and BH team and all who report finded bugs.
Do I think I should stick with 172 or move to 178 last time
I tryed I had all kinds of problems and went back to old one
Only you can decide what is best for you.
You asked what is the best version for the Duo, and I concur with the answers above -1.7.8.
Why don't you upgrade and tell us what "all kinds of problems" you have with 1.7.8?
I doubt there is anything that can not be fixed.
