I usually use usb pen drive which is smaller than 4GB for my Du2. However, the pen drive which is smaller 4GB becomes not popular in the market. What is the largest capacity of an usb pen drive the Vu+ Duo2 support?
@nunigaia, thank for the additional information. The large USB 2 drive is much easy to buy. Have you tried any USB 3 drive? Usually, a higher version is down compatible to a lower version. I will buy a usb 2 drive first.
Best Regards
mysat-bs
Thanks for the informtion. A large USB 2 drive is widely available.No, i've not tried. But it seems too, that some users have troubles with USB devices, and probably they are usb 3.0 devices.
