What's the correct path for reboot, restart enigma 2 and standby ???
TigerSat
I have just installed OBH image on my Vu+ Zero 4 K.
Now if I want to use crontab, what will be the correct path for this commands :
00 04 * * * /usr/bin/Blackholecmd reboot
03 04 * * * /usr/bin/Blackholecmd restartenigma2
03 05 * * * /usr/bin/Blackholecmd standby
There is no Blackholecmd in OBH....where can I find the corect path ?
Thanks
OBH does not need the complications of BH to use crontimers: it is a built-in feature!
Just go to Timer menu and you'll find the Crontimer function, along with the very useful Autotimer and Powertimers.
If you already have your crontimers files, you can put them in
/etc/cron/crontabs
but my advice is to copy only the real crontimers, not also the powertimers and to create them directly by the image.
yes and no
I had to calculate and add the time of 180 seconds until it's doing the actual command.
So, if I want to reboot the box at 05:00.....at 05:00 it appear a warning on the screen that the box will be rebooting and start counting from 180 sec down to reboot.
the rebooting itself at this image is aprox . 55-60 sec + 180 sec the warning on the screen....altogether. So I put it at 300 sec ( 5 min )
if you wanna put more commands you have to be carrifull and add those warning sec. It was better if we could choose how many minutes to apear on the scrin this warning. My opinion is 1 minute is enough ....3 min too much
Anyway, the time and date work perfect......which I need it work crontime.
The Image is very fast with Vu+Zero 4K
Good work.
