Which 4K HDR VU+ model?
said006
Hi,
which 4K HDR PVR from VU+ 4k models would you recommend for me:
I only need 1 Satelite tuner, no recording required.
Internal or external HDD required
IPTV needed
Using as mediaplayer, I want to play 4k HDR movies on my SSD via USB, mostly 50 - 80 GB per movie.
No extra's needed.
As cheap model as possible.
Thanks in advance!
Hi,
IPTV needed
No extra's needed.
Thanks in advance!
Lately I have Uno 4k SE....It is excelant.
Other one would be Vu Zero,,,,And its good with budget price.
Check vuplus site and read more for specification that fit your needs.
Tap the Ad of Vu+ ,,,it will take you there.
Greeting,
a911
I think the Uno 4K SE is better ... since you want to connect an external SSD, the USB connection already supports 3.0.
Thanks everyone, I bought the Solo 4K and very happy with it.
It plays 4K HDR Remux mkv files seamlessly so can also be used as a mediaplayer!
Has builtin wifi (only 2.4 ghz though)
I caught one for 190 euros with a 2 tb harddisk
Hi, where did you find the solo 4k at this price?
