McrRed
He means they're not yet working on the Blackhole version of xbmc. Yes, they work fine on other platforms.Not sure what you mean by this? These channels are working on Tsmedia, my Android media player and pc.
working test beta1 xbmc @"plugin.video.F.T.V-1.2.3a" and "kodi-14.0-Helix+plugin.video.F.T.V-1.3.0a on PCI've read that several times and still don't know what it meansÖKworking test beta1 xbmc @"plugin.video.F.T.V-1.2.3a" and "kodi-14.0-Helix+plugin.video.F.T.V-1.3.0a on PC
Seen some logs elsewhere suggesting pysqlite2 or possibly python-sqlite3 are missing from the BH image causing dependencies to report script errors...
This is solely about which addons dont/do work on XBMC!..Not sure what you mean by this? These channels are working on Tsmedia, my Android media player and pc.
I did a search for 'sqlite' and found these in the other image.. you could check to see if there in BH one..
libsqlite3.so.0 /usr/lib File folder
sqlite3 /usr/lib/python2.7 File folder
_sqlite3 /usr/lib/python2.7/lib-dynload SO File
libsqlite3.so.0.8.6 /usr/lib 6 File
after installing python-sqlite3 genesis phoenex and salts are woking fine navi-x does not work
As above. Multiple users saying installing sqlite gets popular addons like fusion working.Just want to share my experience I tried the BH image and most of the XBMC addons do not work than I tried VTI image and found more addons working fine without any errors I don't know if its something to do with the new drivers .
Edit:
I'm wondering if it's as simple as vti including sqlite and BH not....
