Which device should I purchase
Ross Nicholson
Hi,
I've made up my mind to purchase a VU Plus device but I'm not sure which one I should get.
My setup is quite simple. I have two DVB-S2 signal cables and 1 DVB-T cable. Based in Ireland and have Saorview (DVBT) and Freesat (DVBS). Probably 2 tuners for each.
The device will primarily be a network device feeding Kodi, there won't actually be a TV at the device location. I would like the EPG to be taken from the feed for both Saorview and Freesat,
Would like to know my options for 1) HD signals and 2) 4K for future proofing. Being able to record is a must.
If this is the wrong forum in which to post please let me know.
Thanks in advance,
Ross
As you have mentioned 4K the only one available at present is the Solo 4K which should suit your needs
Can you tell me how many network streams the device could support? Assuming no transcoding is required is it equal to the number of tuners or less than that? Or is there anyway I can find out.
Thanks again.
