Which images can I use in Vu+ Duo²
If you install Blackhole then you will be using one of the best there is...... but there are others, openvix / openatv / openpli just to name a few.
Hi Vlademirs
I know, cause i have talked to you severall times, you boughted VUplus Duo2 STB.
Who buys, STB´S enigma2 based Linux receivers, search knowledge, experimentation, an difference on TV Viewing!
In that case, i think, you must go to the last image and enjoy, a new experience for Sat - Cable - Entertainment TV Viewing.
If you haven´t install any image, go for, the lastest Blackhole XBMC Beta2
Thanks a lot . I´ll install BH XBMC Beta2 when my receiver arrives...
Can I change Confluence skin by another ?
Yes, but it´s better that you configure all that you can with confluence.
Upon then, change as you like!
by the away ... you are in Portugal or in Brazil?
You have a excelent choice on buying Vu Duo2!
For me, it´s the better STB in the World.
Well, time for sleeping
bye
See you
Oh Yeah,
When I knew that Duo² uses BCM7424 chip I definitively choice this STB !
broadcom.com/products/Cable/Cable-Set-Top-Box-Solutions/BCM7424
