Which plugin?
Dijsil
I ve just got a vu solo and imaged it with blackhole image.
When i switch it on it doesnt load a channel automaticcally, i have to go into the channels and choose.
Is there a plugin available that
- when you switch on the decoder it switches to a chosen fta channel.
- also a timer that lets say at 3am if the vu is on any channel (not fta) it switches to FTA.
Q?R1-Use the plugin Startup Services from Image add-on server!
Q?R2- May be the BH Corn Manager (press 2XBule Button) or make a command script,,,,,However,I am not sure ,never done it!
