White line on lcd problem
sansiso
Hi mates. Yesterday all in a sudden a tiny vertical white line appears on my vu+duo2 lcd.Any good advices.
Thanks.
There's not much advice to give, as it's the same as any LCD screen, which can become damaged.
If it's just a software problem it should clear up by turning the power off, either at the rear, or at the plug, then turning it back on again.
If it is physically damaged, you contact vuplus you might be able to buy a new LCD screen, but then you need to either replace it yourself, if your electronic skills are up to it, or get someone to replace it for you.
http://www.vuplus.com/sub/main.php
Thanks a lot for your help.
When someone asks ingenuous questions, it's better not to reply. What do you want do, here, in a forum dedicated to one of the operative system for the VU+ decoders, with a clear HW problem? Take it to an electronic technician! What would you think we can answer?
A LCD display is a LCD display, wherever you put it.
