Why Duo2 can not connect to hidden network ???
saeed.agha
Hi
I have duo2 .
image Bh 2.1.0.
when I want to connect to hidden network , it can not .
and when in router change the setting to " enable SSID " it can connect .
other setting : wpa2 personal , AES , ch6 , ...
and other setting in box and router is similar .
can anyone help me ?
thnks.
make sure you type the ssid exactly as is on the router, it should find ok, then type in the wpa2 code. all should be ok.
Consider that if you have WPA2 Personal with AES your network is pretty secure.
A hacker who would seriuosly attack and break your wireless network can find your hidden SSID in just a couple of second.;)
Hiding the SSID doesn't offer any real greater security than WPA2.
