Why VU+Ultimo does not recognize C-Band Frequncies
al_madhi
Look at my diagram shown below and answer my question why VU+Ultiom does not recognize the C-Band Frequencies Please Advice and elaporate on your respond and comments
Please upload any file/pic/image with your post,,,,using the Board Tool : Upload a File
thank you.
I do not use C Band
But
Have you tried
in Tuner Reception Settings
Advanced configuration mode
LOF >> C-Band
In your Diseqc settings, I had more luck with positions AA, AB, BA and BB rather than 1, 2, 3, 4, etc.
Might be worth a shot if you haven't tried that yet.
Thanks fumbduck for reply and help
using ( positions AA, AB, BA and BB ) This is when using DiSEqC Mode 1.1
But I am using DiSEqC Mode 1.0
Using Simple installation you can not change LNB configuration from Ku to C-Nand
but in Advance installation you can change LNB configuration to C-Band But input frequncies manually
And you can not do Auto search at Advance mode . Please Advice
Best Regards
A.M.AL-MADHI
Best Regards
A.M.AL-MADHI
I can use Auto search in advanced mode.
I would definitely try changing your settings to advanced mode.
