Wifi adapter recommendation for Black Hole 3.0.2.H Kodi Vu+ Solo2
Burak Demircan
Hi,
I need to buy a usb wifi adapter for Black Hole 3.0.2.H Kodi Vu+ Solo2. Can you recommend me any working device which has a driver already. I tested couple of but they either did not work or had crc errors.
Regards
Burak
Hi,
Regards
Burak
I don't recommend wireless solution because ALL Enigma2 boxes suck in WiFi drivers, either it's not supported or will be slow/choppy.
For best experience try to connect the box via Gigabit LAN.
However, If you insist in going for the WiFi direction, best recognized adapter in most images is the original VU+ 300Mb/s dongle.
amazon .de /VU-Wireless-Adapter-incl-Setup/dp/B00AFX847S
P.S. I'm not related to Amazon or that shop in any way, URL posted just for show purposes only.
