wifi and vuplus duo
joselito
Hi ! i have just had my new VuPlus Duo receiver, and would like to know which kind of usb stick in order to setup my wifi with it. thanks
image pli.
image pli.
At the moment the sticks with rt73 chipsets are supported.
We are working to make support for some other wifi sticks.
Hi
I have d-link DWA-110, it is rt73 chipset, I failed it work with my VU PLUS DU.
I hope I can get help.
regards
Very strange.
Could you please report the output of this command (to be launched in a telnet session on your box)?
cat /proc/bus/usb/devices
Your device must be connected to the box.
Very strange.
OpenEmbedded Linux bm750
Vuplus 2.0.4 + BlackHole 1.4.5 bm750
bm750 login: root
Password:
root@bm750:~# cat /proc/bus/usb/devices
T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0000 ProdID=0000 Rev= 2.06
S: Manufacturer=Linux 2.6.18-7.3 ohci_hcd
S: Product=BRCM OHCI
S: SerialNumber=ohci-brcm
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=255ms
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
S: Manufacturer=Linux 2.6.18-7.3 ehci_hcd
S: Product=BRCM EHCI
S: SerialNumber=ehci-brcm
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=256ms
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=08ec ProdID=0015 Rev= 2.00
S: Manufacturer=Kingston
S: Product=DT Elite HS 2.0
S: SerialNumber=0D30466133922881
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=140mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
root@bm750:~#
bm750 login: root
Password:
root@bm750:~#
Seems that your wifi device is not correctly recognized by your box.
Try to change usb port or use an hub usb (with external CA if preferred).
To see if your wifi stick is correctly recognized, launch the command again and compare the output: you should see a new entry.
