Wifi not Work with Hidden SSID Broadcast
tyro
why all version of Blackhole have problem with hidden ssid ??
I hope fixing this issue in next update .
I know this trick but that not solution .
it requires a show\hide every time when you disable device .
So. It works, but you miss the connection when you reboot your system, or when disconnecting the device.
Right?
I think I will be switching to VTI :]
Right?
Right, when toggle "use device" to off in adapter settings.
anyway return to unhide.
thanx
