wifi.txt : RTL8191S WLAN Adapter down
magictails
hi
i have a pb with my usb key
works on win 7 & 8 & ubuntu 10.14 but not works on my stb bhl 2.1.5 ( i tested other img to )
with DHCP or manuel not associated
wep encryption
i looking for to web but all in german language
copy of interface file
# automatically generated by enigma 2
# do NOT change manually!
auto lo
iface lo inet loopback
iface wlan0 inet static
    address 192.168.0.15
    netmask 255.255.255.0
    gateway 192.168.0.1
    pre-up wpa_supplicant -iwlan0 -c/etc/wpa_supplicant.conf -B -Dwext
    post-down wpa_cli terminate
auto eth0
iface eth0 inet static
    address 192.168.137.130
    gateway 192.168.137.1
rj45 & laptop to STB & DCC E2 v1.50 for command
wifi.txt repport
T:  Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=12  MxCh= 2
B:  Alloc=  0/900 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 1.10 Cls=09(hub  ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=0000 ProdID=0000 Rev= 2.06
S:  Manufacturer=Linux 2.6.18-7.4-dm800 ohci_hcd
S:  Product=BRCM OHCI
S:  SerialNumber=ohci-brcm
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=  0mA
I:  If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
E:  Ad=81(I) Atr=03(Int.) MxPS=   2 Ivl=255ms
T:  Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=12  MxCh= 2
T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480 MxCh= 2
B:  Alloc=  0/800 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
S:  Manufacturer=Linux 2.6.18-7.4-dm800 ehci_hcd
S:  Product=BRCM EHCI
S:  SerialNumber=ehci-brcm
E:  Ad=81(I) Atr=03(Int.) MxPS=   2 Ivl=256ms
T:  Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  2 Spd=480 MxCh= 0
D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=0fce ProdID=e0bc Rev=94.07
S:  Product=CCR-60
S:  SerialNumber=07110227000A
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I:  If#= 0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E:  Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
T:  Bus=01 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#=  3 Spd=480 MxCh= 0
P:  Vendor=0bda ProdID=8172 Rev= 2.00
S:  Manufacturer=Manufacturer Realtek
S:  Product=RTL8191S WLAN Adapter
S:  SerialNumber=00e04c000001
I:  If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=ff Prot=ff Driver=r871x_usb_drv
E:  Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=0d(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
eth0      Link encap:Ethernet  HWaddr 00:09:34:29:47:08
          inet addr:192.168.137.130  Bcast:0.0.0.0  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:4467 errors:0 dropped:0 overruns:0 frame:0
          TX packets:5004 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1070113 (1.0 MiB)  TX bytes:448041 (437.5 KiB)
          Interrupt:16
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:56 errors:0 dropped:0 overruns:0 frame:0
          TX packets:56 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:4340 (4.2 KiB)  TX bytes:4340 (4.2 KiB)
wlan0     unassociated  Nickname:"rtl_wifi"
          Mode:Auto  Access Point: Not-Associated   Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
          Link Quality:0  Signal level:0  Noise level:0
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
wlan0     No scan results
pcr0 pidchannel
[  489.030000] MPEG
[  489.032000] audio: decoder start 0
[  489.047000] video delay 0 (0 ms)
[  489.047000] total video delay: 0 (0 ms)
[  489.052000] start video0 on dmx 0 pid:2c6
[  489.052000] total video delay: 0 (0 ms)
[  489.062000] VIDEO0: start decode
[  493.419000] ch0: lock
[  493.491000] RAP first pts 0x10bd183aa, stc 0x10bd17a74, pcr valid
[  493.574000] RAP sampling rate info isr (48000)
[  493.574000] eBitRateChange Isr.. set source_changed_event!
[  493.574000] eModeChange Isr.. set source_changed_event!
[  493.947000] VIDEO0: first pts 0x10bd33a70
[  493.947000] VIDEO0: resolution changed (720 576)
[  494.098000] enable tsm0
[  494.127000] VIDEO0: progressive changed (0)
[  562.013000] stop pcr0 on dmx 0 pid:2c6
[  562.014000] stop video0 on dmx 0 pid:2c6
[  562.016000] VIDEO0: stop decode
[  562.018000] VIDEO0: set blank to 1
[  562.020000] audio: decoder stop
[  562.036000] stop audio on dmx 0 pid:2d1
[  562.036000] audio: xpt stop(2)
[  562.036000] no decoder left in sync handling so disable xpt_sync
[  562.036000] bcm_audio_channel_stop(2) done
[  562.544000] VIDEO0: dst_left, dst_top, dst_width and dst_height is 0.. reset to defaults!
[  562.671000] set current avs auto aspect to 16:9
[  562.671000] disable wss on display 0
[  562.671000] set wss 7 on display 1
[  562.671000] set sb to 3(1)
[  562.718000] pilot_off!
[  563.722000] cx24116_llf: cmd 11 timed out
[  563.737000] unknown fec code: 0
[  563.816000] start pcr0 on dmx 0 pid:22c index 2
[  563.819000] start audio on dmx 0 pid:6a
[  563.819000] audio xpt start
[  563.819000] sync is off so we enable it
[  563.819000] demux-index 0 pcr0pid 22c
[  563.819000] using 2 as pcr0 pidchannel
[  563.820000] MPEG
[  563.821000] audio: decoder start 0
[  563.835000] video delay 0 (0 ms)
[  563.835000] total video delay: 0 (0 ms)
[  563.838000] VIDEO0: set streamtype!
[  563.838000] set H264
[  563.838000] sw rave disabled!
[  563.838000] audio delay 18000 (200 ms)
[  563.838000] total video delay: 18000 (200 ms)
[  563.842000] start video0 on dmx 0 pid:22c
[  563.842000] total video delay: 18000 (200 ms)
[  563.851000] VIDEO0: start decode
[  574.288000] ch0: lock
[  574.342000] RAP first pts 0x15f4847ce, stc 0x15f4831ca, pcr valid
[  574.662000] RAP sampling rate info isr (48000)
[  574.662000] eBitRateChange Isr.. set source_changed_event!
[  574.662000] eModeChange Isr.. set source_changed_event!
[  574.951000] VIDEO0: first pts 0x15f49cc7c
[  574.952000] VIDEO0: resolution changed (1920 1080)
[  575.106000] enable tsm0
[  575.348000] stop pcr0 on dmx 0 pid:22c
[  575.352000] stop video0 on dmx 0 pid:22c
[  575.372000] VIDEO0: stop decode
[  575.374000] VIDEO0: set blank to 1
[  575.376000] audio: decoder stop
[  575.390000] stop audio on dmx 0 pid:6a
[  575.390000] audio: xpt stop(3)
[  575.390000] no decoder left in sync handling so disable xpt_sync
[  575.390000] bcm_audio_channel_stop(3) done
[  575.907000] VIDEO0: dst_left, dst_top, dst_width and dst_height is 0.. reset to defaults!
[  576.011000] set current avs auto aspect to 16:9
[  576.011000] disable wss on display 0
[  576.012000] set wss 7 on display 1
[  576.012000] set sb to 3(1)
[  577.086000] cx24116_llf: cmd 11 timed out
[  577.100000] unknown fec code: 0
[  577.182000] start pcr0 on dmx 0 pid:2c6 index 2
[  577.184000] start audio on dmx 0 pid:2d1
[  577.184000] audio xpt start
[  577.185000] sync is off so we enable it
[  577.185000] demux-index 0 pcr0pid 2c6
[  577.185000] using 2 as pcr0 pidchannel
[  577.187000] MPEG
[  577.189000] audio: decoder start 0
[  577.204000] audio delay 18000 (200 ms)
[  577.204000] total video delay: 18000 (200 ms)
[  577.207000] VIDEO0: set streamtype!
[  577.207000] set MPEG2
[  577.207000] sw rave disabled!
[  577.207000] video delay 0 (0 ms)
[  577.207000] total video delay: 0 (0 ms)
[  577.210000] start video0 on dmx 0 pid:2c6
[  577.211000] total video delay: 0 (0 ms)
[  577.221000] VIDEO0: start decode
[  578.572000] ch0: lock
[  578.597000] RAP first pts 0x10c46630a, stc 0x10c465a48, pcr valid
[  578.679000] RAP sampling rate info isr (48000)
[  578.679000] eBitRateChange Isr.. set source_changed_event!
[  578.679000] eModeChange Isr.. set source_changed_event!
[  579.791000] VIDEO0: first pts 0x10c490070
[  579.792000] VIDEO0: resolution changed (720 576)
[  579.943000] enable tsm0
[  608.866000] VIDEO0: dst_left, dst_top, dst_width and dst_height is 0.. reset to defaults!
[  608.993000] set current avs auto aspect to 16:9
[  608.993000] disable wss on display 0
[  608.994000] set wss 7 on display 1
[  608.994000] set sb to 3(1)
[  675.966000] ch0: unlock
[  678.534000] ch0: lock
[  678.535000] ignore pts error when audio is not running
[  678.583000] ignore pts error when audio is not running
[  678.597000] XVD pts error PTS 0x86667948, STC 0x8667d713, type 0
[  678.885000] rap watchdog flush!
[  678.885000] flush audio decode
[  678.913000] video delay 0 (0 ms)
[  678.913000] total video delay: 0 (0 ms)
[  678.940000] ch0: lock
[  679.036000] RAP first pts 0x10cd051fa, stc 0x10cd04894, pcr valid
[  679.335000] RAP sampling rate info isr (48000)
[  679.336000] eBitRateChange Isr.. set source_changed_event!
[  679.336000] eModeChange Isr.. set source_changed_event!
[  685.998000] ch0: unlock
[  686.958000] ch0: lock
[  686.958000] ignore pts error when audio is not running
[  687.006000] ignore pts error when audio is not running
[  687.308000] rap watchdog flush!
[  687.308000] flush audio decode
[  687.336000] video delay 0 (0 ms)
[  687.336000] total video delay: 0 (0 ms)
[  687.365000] ch0: lock
[  687.461000] RAP first pts 0x10cdbe38a, stc 0x10cdbda78, pcr valid
[  687.759000] RAP sampling rate info isr (48000)
[  687.760000] eBitRateChange Isr.. set source_changed_event!
[  687.760000] eModeChange Isr.. set source_changed_event!
[ 1081.857000] ch0: unlock
[ 1084.977000] ch0: lock
[ 1084.977000] ignore pts error when audio is not running
[ 1085.001000] ignore pts error when audio is not running
[ 1085.025000] ignore pts error when audio is not running
[ 1085.073000] ignore pts error when audio is not running
[ 1085.098000] ignore pts error when audio is not running
[ 1085.099000] XVD pts error PTS 0x877d4e88, STC 0x877ef621, type 0
[ 1085.327000] rap watchdog flush!
[ 1085.327000] flush audio decode
[ 1085.355000] video delay 0 (0 ms)
[ 1085.355000] total video delay: 0 (0 ms)
[ 1085.387000] ch0: lock
[ 1085.551000] RAP first pts 0x10efe945a, stc 0x10efe8b1a, pcr valid
[ 1085.850000] RAP sampling rate info isr (48000)
[ 1085.850000] eBitRateChange Isr.. set source_changed_event!
[ 1085.850000] eModeChange Isr.. set source_changed_event!
[ 1101.873000] ch0: unlock
[ 1107.585000] ch0: lock
[ 1107.700000] XVD pts error PTS 0x878b1130, STC 0x878e7ae5, type 0
[ 1107.935000] rap watchdog flush!
[ 1107.935000] flush audio decode
[ 1107.962000] video delay 0 (0 ms)
[ 1107.962000] total video delay: 0 (0 ms)
[ 1107.991000] ch0: lock
[ 1108.015000] RAP first pts 0x10f1d6dda, stc 0x10f1d64a4, pcr valid
[ 1108.314000] RAP sampling rate info isr (48000)
[ 1108.314000] eBitRateChange Isr.. set source_changed_event!
[ 1108.314000] eModeChange Isr.. set source_changed_event!
[ 1151.889000] ch0: unlock
[ 1157.913000] ch0: lock
[ 1157.913000] ignore pts error when audio is not running
[ 1158.263000] rap watchdog flush!
[ 1158.263000] flush audio decode
[ 1158.290000] video delay 0 (0 ms)
[ 1158.290000] total video delay: 0 (0 ms)
[ 1158.320000] ch0: lock
[ 1158.344000] RAP first pts 0x10f628b4a, stc 0x10f62820a, pcr valid
[ 1158.642000] RAP sampling rate info isr (48000)
[ 1158.643000] eBitRateChange Isr.. set source_changed_event!
[ 1158.643000] eModeChange Isr.. set source_changed_event!
[ 1181.890000] ch0: unlock
[ 1183.720000] out of order segment: rcv_next 3EBEED00 seq 3EBEED4C - 3EBEED83
[ 1183.723000] out of order segment: rcv_next 3EBEED00 seq 3EBEED83 - 3EBEEDB3
[ 1183.726000] out of order segment: rcv_next 3EBEED00 seq 3EBEEDB3 - 3EBEEDE3
[ 1183.726000] out of order segment: rcv_next 3EBEED00 seq 3EBEEDE3 - 3EBEEE1A
[ 1183.726000] out of order segment: rcv_next 3EBEED00 seq 3EBEEE1A - 3EBEEE4A
[ 1183.727000] out of order segment: rcv_next 3EBEED00 seq 3EBEEE4A - 3EBEEE73
[ 1183.731000] out of order segment: rcv_next 3EBEED00 seq 3EBEEE73 - 3EBEEEAA
[ 1183.731000] out of order segment: rcv_next 3EBEED00 seq 3EBEEEAA - 3EBEEED3
[ 1183.780000] out of order segment: rcv_next 3EBEED00 seq 3EBEEED3 - 3EBEF473
[ 1183.782000] out of order segment: rcv_next 3EBEED00 seq 3EBEF473 - 3EBEF47A
[ 1183.785000] out of order segment: rcv_next 3EBEED00 seq 3EBEF47A - 3EBEF4A3
[ 1183.788000] out of order segment: rcv_next 3EBEED00 seq 3EBEF4A3 - 3EBEFA43
[ 1183.791000] ofo requeuing : rcv_next 3EBEED4C seq 3EBEED4C - 3EBEED83
[ 1183.791000] ofo requeuing : rcv_next 3EBEED83 seq 3EBEED83 - 3EBEEDB3
[ 1183.791000] ofo requeuing : rcv_next 3EBEEDB3 seq 3EBEEDB3 - 3EBEEDE3
[ 1183.791000] ofo requeuing : rcv_next 3EBEEDE3 seq 3EBEEDE3 - 3EBEEE1A
[ 1183.791000] ofo requeuing : rcv_next 3EBEEE1A seq 3EBEEE1A - 3EBEEE4A
[ 1183.791000] ofo requeuing : rcv_next 3EBEEE4A seq 3EBEEE4A - 3EBEEE73
[ 1183.791000] ofo requeuing : rcv_next 3EBEEE73 seq 3EBEEE73 - 3EBEEEAA
[ 1183.791000] ofo requeuing : rcv_next 3EBEEEAA seq 3EBEEEAA - 3EBEEED3
[ 1183.791000] ofo requeuing : rcv_next 3EBEEED3 seq 3EBEEED3 - 3EBEF473
[ 1183.791000] ofo requeuing : rcv_next 3EBEF473 seq 3EBEF473 - 3EBEF47A
[ 1183.792000] ofo requeuing : rcv_next 3EBEF47A seq 3EBEF47A - 3EBEF4A3
[ 1183.792000] ofo requeuing : rcv_next 3EBEF4A3 seq 3EBEF4A3 - 3EBEFA43
[ 1187.434000] ch0: lock
[ 1187.434000] ignore pts error when audio is not running
[ 1187.483000] ignore pts error when audio is not running
[ 1187.784000] rap watchdog flush!
[ 1187.784000] flush audio decode
[ 1187.811000] video delay 0 (0 ms)
[ 1187.811000] total video delay: 0 (0 ms)
[ 1187.840000] ch0: lock
[ 1187.935000] RAP first pts 0x10f8b2eba, stc 0x10f8b2558, pcr valid
[ 1188.235000] RAP sampling rate info isr (48000)
[ 1188.235000] eBitRateChange Isr.. set source_changed_event!
[ 1188.235000] eModeChange Isr.. set source_changed_event!
[ 1188.245000] XVD pts error PTS 0x87c1ea98, STC 0x87c5c90a, type 0
[ 1211.938000] ch0: unlock
[ 1212.970000] ch0: lock
[ 1212.970000] ignore pts error when audio is not running
[ 1213.320000] rap watchdog flush!
[ 1213.320000] flush audio decode
[ 1213.347000] video delay 0 (0 ms)
[ 1213.347000] total video delay: 0 (0 ms)
[ 1213.386000] ch0: lock
[ 1213.424000] RAP first pts 0x10fae2f5a, stc 0x10fae2634, pcr valid
[ 1213.723000] RAP sampling rate info isr (48000)
[ 1213.723000] eBitRateChange Isr.. set source_changed_event!
[ 1213.723000] eModeChange Isr.. set source_changed_event!
[ 1261.977000] ch0: unlock
[ 1267.629000] XVD pts error PTS 0x87f8a0d8, STC 0x87fc4b2c, type 0
[ 1267.666000] ch0: lock
[ 1267.666000] ignore pts error when audio is not running
[ 1267.690000] ignore pts error when audio is not running
[ 1267.714000] ignore pts error when audio is not running
[ 1267.738000] ignore pts error when audio is not running
[ 1267.762000] ignore pts error when audio is not running
[ 1267.786000] ignore pts error when audio is not running
[ 1267.834000] ignore pts error when audio is not running
[ 1268.016000] rap watchdog flush!
[ 1268.016000] flush audio decode
[ 1268.044000] video delay 0 (0 ms)
[ 1268.044000] total video delay: 0 (0 ms)
[ 1268.073000] ch0: lock
[ 1268.073000] RAP first pts 0x10ff93b8a, stc 0x10ff9329a, pcr valid
[ 1268.371000] RAP sampling rate info isr (48000)
[ 1268.371000] eBitRateChange Isr.. set source_changed_event!
[ 1268.371000] eModeChange Isr.. set source_changed_event!
[ 1322.050000] ch0: unlock
[ 1323.932000] XVD pts error PTS 0x88223d30, STC 0x8822f429, type 0
[ 1323.947000] ch0: lock
[ 1323.947000] ignore pts error when audio is not running
[ 1323.995000] ignore pts error when audio is not running
[ 1324.297000] rap watchdog flush!
[ 1324.297000] flush audio decode
[ 1324.325000] video delay 0 (0 ms)
[ 1324.325000] total video delay: 0 (0 ms)
[ 1324.353000] ch0: lock
[ 1324.453000] RAP first pts 0x11046a73a, stc 0x110469f80, pcr valid
[ 1324.748000] RAP sampling rate info isr (48000)
[ 1324.748000] eBitRateChange Isr.. set source_changed_event!
[ 1324.748000] eModeChange Isr.. set source_changed_event!
[ 1363.332000] ch0: unlock
[ 1370.421000] out of order segment: rcv_next F1B91D32 seq F1B922D2 - F1B922D9
[ 1370.425000] ofo requeuing : rcv_next F1B922D2 seq F1B922D2 - F1B922D9
[ 1381.237000] ch0: lock
[ 1381.237000] ignore pts error when audio is not running
[ 1381.255000] XVD pts error PTS 0x883e8058, STC 0x884a506b, type 0
[ 1381.587000] rap watchdog flush!
[ 1381.587000] flush audio decode
[ 1381.614000] video delay 0 (0 ms)
[ 1381.614000] total video delay: 0 (0 ms)
[ 1381.651000] ch0: lock
[ 1381.696000] RAP first pts 0x1109542aa, stc 0x110953bae, pcr valid
[ 1381.988000] RAP sampling rate info isr (48000)
[ 1381.988000] eBitRateChange Isr.. set source_changed_event!
[ 1381.988000] eModeChange Isr.. set source_changed_event!
[ 1423.379000] ch0: unlock
[ 1428.997000] XVD pts error PTS 0x8867b338, STC 0x886b1896, type 0
[ 1429.019000] ch0: lock
[ 1429.019000] ignore pts error when audio is not running
[ 1429.043000] ignore pts error when audio is not running
[ 1429.067000] ignore pts error when audio is not running
[ 1429.091000] ignore pts error when audio is not running
[ 1429.139000] ignore pts error when audio is not running
[ 1429.187000] ignore pts error when audio is not running
[ 1429.369000] rap watchdog flush!
[ 1429.369000] flush audio decode
[ 1429.398000] video delay 0 (0 ms)
[ 1429.398000] total video delay: 0 (0 ms)
[ 1429.426000] ch0: lock
[ 1429.426000] RAP first pts 0x110d6d0da, stc 0x110d6c7c2, pcr valid
[ 1429.618000] XVD pts error PTS 0x8867c850, STC 0x886b859c, type 0
[ 1429.724000] RAP sampling rate info isr (48000)
[ 1429.724000] eBitRateChange Isr.. set source_changed_event!
[ 1429.724000] eModeChange Isr.. set source_changed_event!
[ 1431.812000] stop pcr0 on dmx 0 pid:2c6
[ 1431.814000] stop video0 on dmx 0 pid:2c6
[ 1431.817000] VIDEO0: stop decode
[ 1431.820000] VIDEO0: set blank to 1
[ 1431.822000] audio: decoder stop
[ 1431.835000] stop audio on dmx 0 pid:2d1
[ 1431.835000] audio: xpt stop(3)
[ 1431.836000] no decoder left in sync handling so disable xpt_sync
[ 1431.836000] bcm_audio_channel_stop(3) done
[ 1432.251000] unknown fec code: 0
[ 1432.308000] start pcr0 on dmx 0 pid:87b index 2
[ 1432.311000] start audio on dmx 0 pid:87c
[ 1432.311000] audio xpt start
[ 1432.311000] sync is off so we enable it
[ 1432.311000] demux-index 0 pcr0pid 87b
[ 1432.311000] using 2 as pcr0 pidchannel
[ 1432.314000] MPEG
[ 1432.315000] audio: decoder start 0
[ 1432.331000] video delay 0 (0 ms)
[ 1432.331000] total video delay: 0 (0 ms)
[ 1432.335000] start video0 on dmx 0 pid:87b
[ 1432.335000] total video delay: 0 (0 ms)
[ 1432.343000] VIDEO0: start decode
[ 1432.348000] ch0: lock
[ 1432.507000] RAP first pts 0xc9748350, stc 0xc97467f0, pcr valid
[ 1432.642000] RAP sampling rate info isr (48000)
[ 1432.642000] eBitRateChange Isr.. set source_changed_event!
[ 1432.642000] eModeChange Isr.. set source_changed_event!
[ 1432.678000] VIDEO0: first pts 0xc9751c9e
[ 1432.829000] enable tsm0
[ 1449.251000] out of order segment: rcv_next 85BCA849 seq 85BCADE9 - 85BCADF0
[ 1449.263000] ofo requeuing : rcv_next 85BCADE9 seq 85BCADE9 - 85BCADF0
