Request WiFi USB adapter for Vu+ Zero 4K with BH 3.0.8
indiket
Last week I bought a Vu+ Zero 4K and USB WIFI stick. When changing the original image of the device by the image Black Hole 3.0.8, the wifi has stopped working.
Please, could someone tell me the brand and reference of a wifi usb adapter compatible with Vu+ Zero with black hole 3.0.8? If it can be 600 Mbps, much better.
Thanks in advance.
Thanks in advance.
We need some details about your actual wifi usb stick.
Thankyou angelofsky1980 for your replay.
In the enclosed file are the details of the usb stick.
Thanks again for your time.
Do you have possibility to put your device into Windows PC and take some infos from "Device Manager"?
Or post here the URL where we can download Windows/Linux drivers?
Hello angelofsky1980. Once again, thank you for your response.
As for the first question, I can not get the information requested because apparently Mac has no device manager (this is what I found in the web).
Regarding the second question, I asked at the store where I bought the Vu+ Zero and the USB stick and the only thing they could tell me is that this USB adapter uses the 8811 / 8812au drivers which are not in Black Hole 3.0.8.
Again, thanks for your time.
Uhm .... 8812au is included into BH images but probably your Wifi USB device is not listed in the driver...
This is not true: use the extended infos about your Mac. You'll be prompted of all the devices used. I don't have a USB adapter but, for instance, I have this for my LAN (built-in) adapter, with all the ID needed (these ID lines are written in Italian, in my system, of course, but still there):
Broadcom 57765-B0:
Nome: ethernet
Tipo: Controller Ethernet
Bus: PCI
ID produttore: 0x14e4
ID dispositivo: 0x16b4
ID fornitore sottosistema: 0x14e4
ID sottosistema: 0x16b4
ID revisione: 0x0010
Ampiezza link: x1
Nome BSD: en0
Nome Kext: AppleBCM5701Ethernet.kext
Versione firmware: 57765-a1.54
Posizione: /System/Library/Extensions/IONetworkingFamily.kext/Contents/PlugIns/AppleBCM5701Ethernet.kext
Supporta offload mDNS: 98:5a:eb:d8:a5:65
Versione: 10.3.3
Thanks wilmac for your post. How can I get extended infos in Mac? Could you please tell me the path? I looked in main menu (apple icon) > about this Mac > system report …. Here there is a lot of info in each tab, but in the USB tab the adapter does not appear.
My OS is Mojave 10.14.5.
Regards.
uaaaaaahhhhh!!! EUREKA. When I least expected it, in the double bottom of the stick case, I found a mini CD with all the information on the adapter. Attached file of the contents of the mini cd.
I think the driver number (8812au) that they told me in the store where I bought the stick is not correct and from what I could see in the information of the mini cd the correct number would be 8821au.
I do not know if this information will help solve the problem. What do you think? :thanks:
Not under USB! Your device is not a USB disk or flash drive: it's a wifi (WAN) adapter! You must look under Wi-Fi section.
My system is not in English, so I don't remember what is prompted, but you were almost... arrived. Only, as I said, surely not under USB... ;)
Hi Alexwilmac. Nothing about my adapter appears under the wifi tab or any other tab.
Thanks anyway for your time.
Unfortunately, I don't have a wi-fi adapter to check myself. That's why I had to report, for instance, about LAN. But it's really strange.
Your device is a Realtek 8821AU...
