WiFi USB Dongle Realtek 8188 Oppure 5370CU [MT7601]
BingoBongo11
Ciao a tutti,
Da ho ordinato una Dongle WiFi USB con ChipSet Realtek 8188 Oppure 5370CU (Come da descrizione del venditore), ma non viene riconosciuta in automatico dal mio Vu+ Zero con BH 2.1.5
Avete per caso i Driver oppure un altro modo per farla riconoscere ?
Grazie in Anticipo :D
Ciao a tutti,
Serve il file di debug per i Wifi sennò non si capisce che cosa hai tra le mani: http://www.vuplus-community.net/board/threads/debug-script-per-le-immagini-bh.21514/
Scusa non sapevo servisse.
Ecco il contenuto del file Debug:
Box Info
Kernel: Linux vuzero 3.13.5 #1 SMP Tue Feb 24 04:06:04 CET 2015 mips GNU/Linux
BH Ver: BlackHole 2.1.5
MAC: 00:1D:EC:08:83:9C
USB devices
Bus 001 Device 002: ID 148f:7601
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0001
Kernel Messages
Determined physical RAM map:
 memory: 10000000 @ 00000000 (usable)
 memory: 10000000 @ 20000000 (usable)
bmem: adding 56 MB LINUX region at 7 MB (0x03853000@0x007ad000)
bmem: adding 192 MB RESERVED region at 64 MB (0x0c000000@0x04000000)
bmem: adding 256 MB LINUX region at 512 MB (0x10000000@0x20000000)
Zone ranges:
  Normal   [mem 0x00000000-0x2fffffff]
Movable zone start for each node
Early memory node ranges
  node   0: [mem 0x00000000-0x0fffffff]
  node   0: [mem 0x20000000-0x2fffffff]
On node 0 totalpages: 131072
  Normal zone: 1024 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 131072 pages, LIFO batch:31
Primary instruction cache 32kB, VIPT, 2-way, linesize 64 bytes.
Primary data cache 64kB, 4-way, VIPT, cache aliases, linesize 64 bytes
PERCPU: Embedded 7 pages/cpu @81407000 s7040 r8192 d13440 u32768
pcpu-alloc: s7040 r8192 d13440 u32768 alloc=8*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
Kernel command line: ubiroot rootflags=sync bmem=192M@64M ubi.mtd=rootfs rootfstype=ubifs root=ubi0:rootfs libata.force=1:1.5Gbps
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 315236K/524288K available (6049K kernel code, 275K rwdata, 1184K rodata, 220K init, 114K bss, 209052K reserved)
Hierarchical RCU implementation.
    RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
NR_IRQS:160
Measuring MIPS counter frequency...
Detected MIPS clock frequency: 751 MHz (375.762 MHz counter)
Calibrating delay loop... 749.56 BogoMIPS (lpj=374784)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
SMP: Booting CPU1...
CPU1 revision is: 0002a065 (Broadcom BMIPS4380)
FPU revision is: 00130001
SMP: CPU1 is running
Brought up 2 CPUs
devtmpfs: initialized
NET: Registered protocol family 16
USB0: power enable is active high; overcurrent is active low
bio: create slab <bio-0> at 0
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Initialized.
cfg80211: Calling CRDA to update world regulatory domain
Switched to clocksource wktmr
FS-Cache: Loaded
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Registering unionfs 2.5.13 (for 3.13.7)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
msgmni has been set to 615
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10406800 (irq = 62, base_baud = 5062500) is a 16550A
console [ttyS0] enabled
bootconsole [early0] disabled
serial8250.0: ttyS1 at MMIO 0x10406840 (irq = 63, base_baud = 5062500) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10406880 (irq = 64, base_baud = 5062500) is a 16550A
loop: module loaded
ahci strict-ahci.0: can't get clock
__clk_enable: sata [1]
ahci strict-ahci.0: SSS flag set, parallel bus scan disabled
ahci strict-ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
ahci strict-ahci.0: flags: ncq sntf stag clo slum part
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: FORCE: PHY spd limit set to 1.5Gbps
ata1: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x100 irq 87
ata2: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x180 irq 87
brcmstb_nand: NAND controller driver is loaded
__clk_enable: network [1]
__clk_enable: enet [1]
bcm7552_pm_genet_enable 00
bcmgenet: configuring instance #0 for internal PHY
bcmgenet bcmgenet.0 eth0: link down
__clk_disable: enet [0]
bcm7552_pm_genet_disable 00
__clk_disable: network [0]
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
__clk_enable: usb [1]
bcm7552_pm_usb_enable 00
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 66, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 2
ohci-brcm ohci-brcm.0: irq 67, io mem 0x10480400
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Success! Registering the characther device  success with 0
blackhole initialised
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
hidraw: raw HID events driver (C) Jiri Kosina
ata1: SATA link down (SStatus 0 SControl 310)
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
Key type dns_resolver registered
PM: CP0 COUNT/COMPARE frequency does not depend on divisor
EBI CS0: setting up NAND flash (primary)
NAND device: Manufacturer ID: 0xad, Chip ID: 0xda (Hynix H27U2G8F2CTR-BC)
NAND device: 256MiB, SLC, page size: 2048, OOB size: 64
brcmnand brcmnand.0: 256MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, Hamming ECC
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
Creating 4 MTD partitions on "brcmnand.0":
0x000002100000-0x000010000000 : "rootfs"
0x000002100000-0x000010000000 : "rootfs(redundant)"
0x000000200000-0x000000900000 : "kernel"
0x000000900000-0x000000a00000 : "mac"
UBI: attaching mtd0 to ubi0
usb 1-2: new high-speed USB device number 2 using ehci-brcm
ata2: SATA link down (SStatus 0 SControl 300)
random: nonblocking pool is initialized
UBI: scanning is finished
UBI: attached mtd0 (name "rootfs", size 223 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 1780, bad PEBs: 4, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 13/6, WL threshold: 4096, image sequence number: 1927204792
UBI: available PEBs: 0, total reserved PEBs: 1780, PEBs reserved for bad PEB handling: 36
UBI: background thread "ubi_bgt0d" started, PID 54
ALSA device list:
  No soundcards found.
UBIFS: parse sync
UBIFS: background thread "ubifs_bgt0_0" started, PID 57
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: FS size: 219541504 bytes (209 MiB, 1729 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
UBIFS: reserved for root: 0 bytes (0 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID FBEC30A9-C300-4885-84CE-E67D308C3B9A, small LPT model
VFS: Mounted root (ubifs filesystem) on device 0:13.
devtmpfs: mounted
Freeing unused kernel memory: 220K (80759000 - 80790000)
UBI error: ubi_open_volume: cannot open device 0, volume 0, error -16
NET: Registered protocol family 10
procmk_init
dvb_bcm7362: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (_vuplus_zero_)
bcm7362: hotplug_callback():
Hotplug - status.connected 1:0:0
Hotplug - connecting HDMI to display 0xe
[GP]:brcm_pwm_init
brcm_demux_init: $Id: bcm_demux.c,v 0.7 $
[MPVR]: >> misc_pvr_init
[VID]: 6bcm7335_video_init
[AUD]: 6bcm7335_audio_init
BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (BCM7362 FE)...
Hotplug - status.connected 1:1:2
input: dreambox advanced remote control (native) as /devices/virtual/input/input0
[LCD]: registered
0:0
[DFP]: registered dbox fp
[SC]: registered sci0
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc4
fpga update driver loaded
udevd (119): /proc/119/oom_adj is deprecated, please use /proc/119/oom_score_adj instead.
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1  0
[VID]: VIDEO_PLAY 1  2 0
[VID]: VIDEO_CONTINUE 1  1
[VID]: VIDEO_CLEAR_BUFFER 1  1 0
[VID]: VIDEO_STOP 0  1
[VID]: VIDEO_SELECT_SOURCE 0  0
svc: failed to register lockdv1 RPC service (errno 124).
[LCD]: unknown cmd 0x1015
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -1387332128
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
FE tune
dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
[AUD]: AUDIO_SET_BYPASS_MODE 1
[AUD]: downmix 0 state : 0
[AUD]: AUDIO_PAUSE 1
[AUD]: AUDIO_PLAY 1 decoder start : 0
[VID]: VIDEO_FREEZE 1  0
[VID]: VIDEO_PLAY 1  2 2
[VID]: VIDEO_SLOWMOTION 0    1
[VID]: VIDEO_FAST_FORWARD 0    1
[AUD]: AUDIO_CONTINUE 1 1 aph=0xad66b800
[AUD]: Mute : 0
[AUD]: AUDIO_CHANNEL_SELECT 0
[AUD]: Mute : 0
Modules Loaded
Module                  Size  Used by    Tainted: P
ext2                   56975  0
fpga_directc             493  0
brcmfb                  1590  3
dvb_bcm7362          6597737 26 brcmfb
procmk                  1668  1 dvb_bcm7362
ipv6                  326329 12 [permanent]
Kernel Objects
/lib/modules/3.13.5
/lib/modules/3.13.5/modules.symbols.bin
/lib/modules/3.13.5/modules.ccwmap
/lib/modules/3.13.5/modules.usbmap
/lib/modules/3.13.5/kernel
/lib/modules/3.13.5/kernel/fs
/lib/modules/3.13.5/kernel/fs/nls
/lib/modules/3.13.5/kernel/fs/nls/nls_cp850.ko
/lib/modules/3.13.5/kernel/fs/ext2
/lib/modules/3.13.5/kernel/fs/ext2/ext2.ko
/lib/modules/3.13.5/kernel/fs/fuse
/lib/modules/3.13.5/kernel/fs/fuse/fuse.ko
/lib/modules/3.13.5/kernel/fs/ntfs
/lib/modules/3.13.5/kernel/fs/ntfs/ntfs.ko
/lib/modules/3.13.5/kernel/fs/reiserfs
/lib/modules/3.13.5/kernel/fs/reiserfs/reiserfs.ko
/lib/modules/3.13.5/kernel/lib
/lib/modules/3.13.5/kernel/lib/crc-ccitt.ko
/lib/modules/3.13.5/kernel/net
/lib/modules/3.13.5/kernel/net/802
/lib/modules/3.13.5/kernel/net/802/stp.ko
/lib/modules/3.13.5/kernel/net/llc
/lib/modules/3.13.5/kernel/net/llc/llc.ko
/lib/modules/3.13.5/kernel/net/ipv6
/lib/modules/3.13.5/kernel/net/ipv6/ipv6.ko
/lib/modules/3.13.5/kernel/net/wireless
/lib/modules/3.13.5/kernel/net/wireless/lib80211.ko
/lib/modules/3.13.5/kernel/net/bridge
/lib/modules/3.13.5/kernel/net/bridge/bridge.ko
/lib/modules/3.13.5/kernel/net/mac80211
/lib/modules/3.13.5/kernel/net/mac80211/mac80211.ko
/lib/modules/3.13.5/kernel/drivers
/lib/modules/3.13.5/kernel/drivers/net
/lib/modules/3.13.5/kernel/drivers/net/usb
/lib/modules/3.13.5/kernel/drivers/net/usb/cdc_subset.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/cdc_eem.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/rndis_host.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/usbnet.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/cdc_ether.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/zaurus.ko
/lib/modules/3.13.5/kernel/drivers/net/tun.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k/ath9k_common.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k/ath9k_hw.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k/ath9k_htc.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/carl9170
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/carl9170/carl9170.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/8192cu.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/hostap
/lib/modules/3.13.5/kernel/drivers/net/wireless/hostap/hostap.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/8812au.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rtl818x
/lib/modules/3.13.5/kernel/drivers/net/wireless/rtl818x/rtl8187
/lib/modules/3.13.5/kernel/drivers/net/wireless/rtl818x/rtl8187/rtl8187.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/mt7650u_sta.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/zd1211rw
/lib/modules/3.13.5/kernel/drivers/net/wireless/zd1211rw/zd1211rw.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt73usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2x00usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2800usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2500usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2x00lib.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2800lib.ko
/lib/modules/3.13.5/kernel/drivers/mtd
/lib/modules/3.13.5/kernel/drivers/mtd/nand
/lib/modules/3.13.5/kernel/drivers/mtd/nand/nandsim.ko
/lib/modules/3.13.5/kernel/drivers/usb
/lib/modules/3.13.5/kernel/drivers/usb/serial
/lib/modules/3.13.5/kernel/drivers/usb/serial/usbserial.ko
/lib/modules/3.13.5/kernel/drivers/usb/serial/cp210x.ko
/lib/modules/3.13.5/kernel/drivers/usb/serial/pl2303.ko
/lib/modules/3.13.5/kernel/drivers/usb/serial/ftdi_sio.ko
/lib/modules/3.13.5/kernel/drivers/misc
/lib/modules/3.13.5/kernel/drivers/misc/altera-stapl
/lib/modules/3.13.5/kernel/drivers/misc/altera-stapl/altera-stapl.ko
/lib/modules/3.13.5/kernel/drivers/misc/eeprom
/lib/modules/3.13.5/kernel/drivers/misc/eeprom/eeprom_93cx6.ko
/lib/modules/3.13.5/kernel/drivers/scsi
/lib/modules/3.13.5/kernel/drivers/scsi/sr_mod.ko
/lib/modules/3.13.5/kernel/drivers/cdrom
/lib/modules/3.13.5/kernel/drivers/cdrom/cdrom.ko
/lib/modules/3.13.5/kernel/drivers/media
/lib/modules/3.13.5/kernel/drivers/media/rc
/lib/modules/3.13.5/kernel/drivers/media/rc/bh-rc-core.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c
/lib/modules/3.13.5/kernel/drivers/media/i2c/cx25840
/lib/modules/3.13.5/kernel/drivers/media/i2c/cx25840/cx25840.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/saa7115.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/msp3400.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/tvp5150.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/mt9v011.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/ir-kbd-i2c.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/wm8775.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/cs53l32a.ko
/lib/modules/3.13.5/kernel/drivers/media/pci
/lib/modules/3.13.5/kernel/drivers/media/pci/ttpci
/lib/modules/3.13.5/kernel/drivers/media/pci/ttpci/ttpci-eeprom.ko
/lib/modules/3.13.5/kernel/drivers/media/usb
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dibusb-common.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dw2102.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-cxusb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-af9005.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dib0700.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dibusb-mb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dibusb-mc.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-opera.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-gp8psk.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dtv5100.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-digitv.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-a800.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-m920x.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-cinergyT2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-vp7045.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-vp702x.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-nova-t-usb2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-az6027.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-technisat-usb2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-pctv452e.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-umt-010.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dtt200u.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/b2c2
/lib/modules/3.13.5/kernel/drivers/media/usb/b2c2/b2c2-flexcop-usb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/cx231xx
/lib/modules/3.13.5/kernel/drivers/media/usb/cx231xx/cx231xx.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/cx231xx/cx231xx-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/as102
/lib/modules/3.13.5/kernel/drivers/media/usb/as102/dvb-as102.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/siano
/lib/modules/3.13.5/kernel/drivers/media/usb/siano/smsusb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/tm6000
/lib/modules/3.13.5/kernel/drivers/media/usb/tm6000/tm6000-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/tm6000/tm6000.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/au0828
/lib/modules/3.13.5/kernel/drivers/media/usb/au0828/au0828.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/bh_dvb_usb_v2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/mxl111sf-tuner.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/mxl111sf-demod.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-mxl111sf.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-au6610.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-gl861.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-af9015.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-af9035.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-anysee.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-rtl28xxu.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-lmedm04.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-az6007.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb_usb_v2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-ce6230.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-ec168.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/em28xx
/lib/modules/3.13.5/kernel/drivers/media/usb/em28xx/em28xx.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/em28xx/em28xx-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf-vmalloc.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/bh-videodev.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/tuner.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf2-memops.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/v4l2-common.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/bh-v4l2-common.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf2-vmalloc.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/v4l2-dv-timings.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf2-core.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf-core.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-core
/lib/modules/3.13.5/kernel/drivers/media/dvb-core/bh-dvb-core.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/m88ds3103.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/atbm8830.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cxd2820r.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ix2505v.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ec100.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lg2160.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ves1x93.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lnbp21.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lnbp22.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/sp8870.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/mb86a16.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib8000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/si2165.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/si2168.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/bcm3510.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/sp887x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/isl6421.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/isl6423.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/mt312.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dibx000_common.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s921.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/itd1000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/mt352.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda18271c2dd.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/or51132.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/or51211.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/zl10036.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/zl10039.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/l64781.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib7000m.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib7000p.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dvb-pll.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv6110x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10021.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10023.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10048.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/au8522_dig.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10071.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10086.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/as102_fe.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda1004x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0288.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0297.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0299.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ds3000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/m88rs2000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/zl10353.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0367.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/si21xx.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/hd29l2.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/nxt200x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24110.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24113.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24116.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24117.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24123.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib0070.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s5h1409.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s5h1411.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/au8522_common.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s5h1420.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/a8293.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib0090.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s5h1432.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tua6100.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stb0899.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/mb86a20s.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stb6000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/rtl2830.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/rtl2832.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ts2020.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ves1820.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lgdt3305.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stb6100.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx22700.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx22702.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/af9013.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/af9033.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lgdt330x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib9000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda8261.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0900.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda826x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv090x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/nxt6000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib3000mb.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib3000mc.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv6110.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/drxd.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/drxk.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lgs8gxx.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners
/lib/modules/3.13.5/kernel/drivers/media/tuners/m88ts2022.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt20xx.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc2580.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mxl5005s.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mxl5007t.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda18212.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda18218.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda18271.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tua9001.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/xc4000.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tuner-xc2028.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tuner-simple.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/max2165.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mc44s803.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/r820t.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tea5761.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tea5767.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/e4000.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/qt1010.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc0011.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc0012.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc0013.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda9887.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tuner_it913x.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2060.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2063.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tuner-types.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda8290.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2131.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda827x.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/xc5000.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2266.ko
/lib/modules/3.13.5/kernel/drivers/media/common
/lib/modules/3.13.5/kernel/drivers/media/common/b2c2
/lib/modules/3.13.5/kernel/drivers/media/common/b2c2/b2c2-flexcop.ko
/lib/modules/3.13.5/kernel/drivers/media/common/cx2341x.ko
/lib/modules/3.13.5/kernel/drivers/media/common/cypress_firmware.ko
/lib/modules/3.13.5/kernel/drivers/media/common/tveeprom.ko
/lib/modules/3.13.5/kernel/drivers/media/common/bh_cypress_firmware.ko
/lib/modules/3.13.5/kernel/drivers/media/common/siano
/lib/modules/3.13.5/kernel/drivers/media/common/siano/smsmdtv.ko
/lib/modules/3.13.5/kernel/drivers/media/common/siano/smsdvb.ko
/lib/modules/3.13.5/kernel/drivers/staging
/lib/modules/3.13.5/kernel/drivers/staging/zram
/lib/modules/3.13.5/kernel/drivers/staging/zram/zram.ko
/lib/modules/3.13.5/kernel/drivers/staging/rtl8712
/lib/modules/3.13.5/kernel/drivers/staging/rtl8712/r8712u.ko
/lib/modules/3.13.5/kernel/drivers/staging/winbond
/lib/modules/3.13.5/kernel/drivers/staging/winbond/w35und.ko
/lib/modules/3.13.5/kernel/drivers/staging/media
/lib/modules/3.13.5/kernel/drivers/staging/media/omap24xx
/lib/modules/3.13.5/kernel/drivers/staging/media/omap24xx/v4l2-int-device.ko
/lib/modules/3.13.5/kernel/drivers/staging/wlan-ng
/lib/modules/3.13.5/kernel/drivers/staging/wlan-ng/prism2_usb.ko
/lib/modules/3.13.5/modules.dep
/lib/modules/3.13.5/modules.isapnpmap
/lib/modules/3.13.5/modules.ieee1394map
/lib/modules/3.13.5/extra
/lib/modules/3.13.5/extra/brcmfb.ko
/lib/modules/3.13.5/extra/fpga_directc.ko
/lib/modules/3.13.5/extra/dvb-bcm7362.ko
/lib/modules/3.13.5/extra/procmk.ko
/lib/modules/3.13.5/modules.dep.bin
/lib/modules/3.13.5/modules.devname
/lib/modules/3.13.5/modules.inputmap
/lib/modules/3.13.5/modules.seriomap
/lib/modules/3.13.5/modules.softdep
/lib/modules/3.13.5/modules.alias
/lib/modules/3.13.5/modules.pcimap
/lib/modules/3.13.5/modules.ofmap
/lib/modules/3.13.5/drivers
/lib/modules/3.13.5/drivers/net
/lib/modules/3.13.5/drivers/net/wireless
/lib/modules/3.13.5/drivers/net/wireless/rt5370sta.ko
/lib/modules/3.13.5/modules.alias.bin
IFConfig output
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:76 errors:0 dropped:0 overruns:0 frame:0
          TX packets:76 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:7036 (6.8 KiB)  TX bytes:7036 (6.8 KiB)
IWConfig output
WLan Scanning - WLAN device
--> WLAN0 interface
WLAN0 - scan
WLAN0 - channel
WLAN0 - rate
WLAN0 - encryption
WLAN0 - power
WLAN0 - wpakeys
WLAN0 - auth
--> WLAN1 interface
WLAN1 - scan
WLAN1 - channel
WLAN1 - rate
WLAN1 - encryption
WLAN1 - power
WLAN1 - wpakeys
WLAN1 - auth
--> WLAN2 interface
WLAN2 - scan
WLAN2 - channel
WLAN2 - rate
WLAN2 - encryption
WLAN2 - power
WLAN2 - wpakeys
WLAN2 - auth
WLan Scanning - RA device
--> RA0 interface
RA0 - scan
RA0 - channel
RA0 - rate
RA0 - encryption
RA0 - power
RA0 - wpakeys
RA0 - auth
--> RA1 interface
RA1 - scan
RA1 - channel
RA1 - rate
RA1 - encryption
RA1 - power
RA1 - wpakeys
RA1 - auth
--> RA2 interface
RA2 - scan
RA2 - channel
RA2 - rate
RA2 - encryption
RA2 - power
RA2 - wpakeys
RA2 - auth
DNS settings
Dumping /etc/resolv.conf ...
nameserver 192.168.1.1
Routing Table
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
Box Info
USB devices
Kernel Messages
Zone ranges:
NR_IRQS:160
Brought up 2 CPUs
FS-Cache: Loaded
loop: module loaded
ALSA device list:
UBIFS: parse sync
devtmpfs: mounted
procmk_init
[GP]:brcm_pwm_init
[LCD]: registered
0:0
FE tune
[AUD]: Mute : 0
[AUD]: Mute : 0
Modules Loaded
ext2                   56975  0
fpga_directc             493  0
brcmfb                  1590  3
Kernel Objects
/lib/modules/3.13.5
IFConfig output
IWConfig output
--> WLAN0 interface
WLAN0 - scan
WLAN0 - channel
WLAN0 - rate
WLAN0 - encryption
WLAN0 - power
WLAN0 - wpakeys
WLAN0 - auth
--> WLAN1 interface
WLAN1 - scan
WLAN1 - channel
WLAN1 - rate
WLAN1 - encryption
WLAN1 - power
WLAN1 - wpakeys
WLAN1 - auth
--> WLAN2 interface
WLAN2 - scan
WLAN2 - channel
WLAN2 - rate
WLAN2 - encryption
WLAN2 - power
WLAN2 - wpakeys
WLAN2 - auth
--> RA0 interface
RA0 - scan
RA0 - channel
RA0 - rate
RA0 - encryption
RA0 - power
RA0 - wpakeys
RA0 - auth
--> RA1 interface
RA1 - scan
RA1 - channel
RA1 - rate
RA1 - encryption
RA1 - power
RA1 - wpakeys
RA1 - auth
--> RA2 interface
RA2 - scan
RA2 - channel
RA2 - rate
RA2 - encryption
RA2 - power
RA2 - wpakeys
RA2 - auth
DNS settings
Routing Table
La tua dongle è una Mediatek 7601 di cui non ho ancora avuto il tempo di compilare il relativo driver.
Ho un esemplare identico alla tua pen. Ho predisposto il driver e lo troverai a breve nel prossimo aggiornamento o nella prossima blackhole.
Tra qualche ora facendo un aggiornamento on-line con un altra penna o con il cavo di rete, dovresti trovarti i driver anche per questa penna wifi..
