WIFI USB RT2870STA on BH 2.0 Problem
Have you tried it with the USB on front or rear ?
If on rear USB use an USB extension cord .
due to noise interferance , found a good location for dongle.
But now working perfect with USB extension cord .
I see 15 different my neighbors wireles networks
Im using Vu+ Wireless dongle with RTL8192cu and I had a similar problem.
I have tried on front abd rear usb and the same problem with my wifi usb on BH 2.0.1.Pleace help me.On BH 1.7.9 was all ok.
I had also a problem with the connection. Two usb dongles with Ralink chipsets RT3070 and RT5370 not received IP address with WPA/WPA2 encryption.​
I solved it by purchasing dongle TP-LINK TL-WN723N (costs only 9 euros) with​
Realtek chipset​
RTL8188CUS. Now it works perfectly
I have this problem ...
I've opened in this section of the Board a theard with some infos about diagnostic file generation.
Please open a thead for your problem, upload in your thread the diagnostic fie and details about your wifi adapter and wifi configuration from your access point/router.
yes.. Ralink RT5572 driver v2.6.1.3 installed and updated.
but the problem still did not improve.
USB wifi stick connected network but IP does not. (DHCP: ON/OFF)
