Wifi: wild ping with OE2 images
donfran
Hi everyone,
I'm having problems with wlan adapters on all OE 2.0 images.
I have two adapters(VU+ n300 adapter and dwl-g122) and same problems with both:
On OE1.6 images when i do a ping test from my laptop ping is stable 2ms-3ms
On OE2.0 fluctuates a lot, its 2ms-580ms
I like BH i don't want to turn to other images yet.
Can somebody help me?
Hi everyone,
First of all, report some infos about your wifi devices following the instruction posted in the thread http://www.vuplus-community.net/board/threads/wifi-drivers-how-to-report-problems.11437/
Specify also your box model and your image version you are using now
I'm little stuck here.
I attached wifi.txt but
when i run script with both adapters i get messages:
lo no wireless extensions.
eth0 no wireless extensions.
lo Interface doesn't support scanning.
eth0 Interface doesn't support scanning.
My box: Vu+ Uno
I have installed BH 2.0.4
wifi.txt is for device VU+ n300 wlan adapter
Please help
My box: Vu+ Uno
Please help
I've seen your output about Vu+ wifi dongle and seems all correct.
I can check it because I've your same box and the same USB dongle.
About DWL-G122 I need to know more infos about your adapter like firmware revision and hardware revision from stick attached in the back of your device
Thanks for quick response agelofsky1980
It would be disappointing for me if there's no fix
i would have to use only OE 1.6 images...
Ping is OK with BH 1.7.9
Please check with your box. I'm curious.
Remember that OE 1.6 images and 2.0 series can uses different driver versions and there should be a different network performances.
Usually with driver upgrades, the performances should be better
I will verify this evening
