will it work?
markyboy156
will the Panasonic DMR-BST940 blu ray recorder work with the vu+ solo2 is there a way of connecting it up so i can record sattelite premium channels to it i already know that you can record to the solo2 hard drive or usb hard drive thanks if so how do you connect it up and set it up properly or can anybody tell me of another recorder that will work with it thanks
I'm not sure what you mean by Satellite Premium channels, but you can record from your Solo 2, to your DMR-BST940 blu ray recorder, using a scart lead.
Just connect a scart lead, from your solo 2, to your recorder, and select AV1, on your recorder. Of course doing this negates the HD quality, but you should also be able to record to a USB device, like a USB stick, and play it back on your recorder, as most DVD recorders/players have this option.
