Solo2 Will not boot
rs trophy
Hello I have got a solo 2 , not a clone it was runing open atv , but is stuck on boot screen. it says booting 99 can not load new image from USB tried five USB . Can I load box with rs 232 cable, with original image from vu , or dose it have to go back to the shop , thanks for any help.
Just load any Solo2 image onto your usb stick and reflash the box.
Make sure no other usb's are connceted to the box and that no backups have been made on the hdd (if you are unsure, disconnect hdd first then try to reflash).
Hello tried to re flash box did not work, disconnected the hdd first . Will I have to send it back to the shop. ? Thanks for any help.
