chaerntejohn
Hi, thought I would try this here as not sure of the actual problem area. Lots of Q&A on the net re playing PC files on VU+ but can't find anything about PC not seeing the VU+ box.
I have had the VU+ Duo2 for over a year, running BH, and when I set it up I just used the network wizard and magically the box HDD appeared on my network (via hub and eternet cable) as another HDD. So I can save movies etc on my pc to watch later.
A couple of weeks ago (no changes to anything) the VU+ HDD was not showing, now and again it would reappear then go again. Only noticed when logging on to it.
I checked Kaspersky and not blocking it, Win7 seemed ok, sees other PCs on network but not VU+
VU+ box network check says all is ok on all tests, so it sees the PC network.
Today I restarted the VU+ network and did something else (not sure what thought I was exiting) in the network menus. Now all is well again.
So, finally the main question, is there a set of things to do to either fix this permanently or just make it work when not there. I don't mind retarting network on the VU+ each time I want to see the HDD as only do this once or twice a week.
Just hoping there is a trick to this.
Regards John
Regards John
