Matrix10
Today I did a little test, how it behaves WLAN and USB stick
on VUplus Ultimo but I believe that this holds for all other.
I definitely found
that if I connect some USB sticks and Wlan dongle one above the other (rear connectors)
I have problems with wlan.
If I plug in the rear/back connector wlan and front connector USB stick then everything works.
So some USB sticks create interference to Wlan dongle if they are both connected to the rear connector one above another.
Who has a problem with the configuration
Disconnect the USB stick and network cable connect only Wlan dongle
configure all the settings manually in the WLAN settings network configuration.
Restart box
