Wireless Lan fix for BH 1.6.2 Beta Images
i have dlink dwa-140 it finds it and i can installe it but no ip adresse same problem with my Realtek 8712 drivers support =Realtek RTL8192GU Wireless LAN 802.11n USB 2.0 Network Adapter dosent either get a ip adresse very sad it does not work :eek:(
I have tried the fix into my Uno (:D) with a rtl871x device (a Sitecom 802.11n 300Mbit device) and all works correctly.
I will test with Duo and my DWA-140 device near this evening.
I have tried the fix into my Uno :)D) with a rtl871x device (a Sitecom 802.11n 300Mbit device) and all works correctly.
tested with Realtek RTL8192GU on dream elite dmm 2.0 beta on my on my dm800 no problems at all, will later test with my dwa-140 FYI :)
I've a DWA-140 and on previous BH works regularly: I think this type of device works correctly also on latest BH.
Remember: this is a VuPlus community :)
i try my usb stick TP-LINk TL-WN321G ver 4.1
not work still did not get any wireless network
wlan connection ok but no network
is there a possibility to solve this problem
Note I have tried on vu+ du & vu+ solo
thank you
thank you
I have into my TODO list to work around RT2870 driver.
Still no support for Atheros chipset, isn't it?
At this moment: no support for Atheros chipset :(
thank you
I have same WIFI usb dongle every things seems all right it recognized by my solo but when i tried to find my access point , it couldnt find any of my 2 wireless Router and both working fine , so what is the problem , I was using this dongle with my previous DSR , NEXT dobrateh 2000 linux base (not open source) satellite receiver and it was working great. any recommendation ?
