Wireless only works with WEP encryption? [rt73 OR other Ralink]
dabezt
Vu+ Solo2 using Blackhole 2.1.0.1
Wifi USB dongle: Ralink Adapter WLAN
The ESSID is configured as WAP2.
In the vu+ solo2 configuration menu -> network -> wlan: Select WAP or WAP/WAP2, input the ESSID, input the password: it doesn't works: unable to create encripted key (or something similar) in spanish= imposible crear la contraseña.
ESSID configured as WEP:
In the vu+ solo2 configuration menu -> network -> wlan: Select WEP, input the ESSID, input the password: it works.
I want to use WAP2 encryption... is it not possible?
Thanks! Regards.
Thnx Erago, but it is in AES:
Network Authentication: WPA2
WPA Encryption: AES
But the problem is not about the router configuration. Vu+ Solo2 doesn't let me configure anything but WEP... if I choose another (WAP, WAP2, etc.) it says: unable to create encription key...
Thnx!
I couldn't hear of anybody else with the same problem, so if it's not a compatibility problem with your wireless router, I might only suggest you to reflash the image without restoring any backup and test the connection in this clean condition.
You can always restore the backup later.
Thanks! Regards.
Post some details about your wifi dongle please.
The dongle:
IpTime USB Wifi Dongle - RT73 USB Wireless LAN Card - Ralink Technology Corp.
Thnx!
