Wlan connections
PeterAlan
Hi
In the wlan panel I can see 2 connections : WLAN and WLAN2 , but I have only one connector beside !
Is this a bug?
The problem comes when I have to reboot the VU+, even if I set only one Wlan, the second one is configured automatically sometimes with the same IP adress than the other Wlan connections !...
Any solution to de-activate the 2nd Wlan.?
Thanks
Moderator
Hi
Is this a bug?
Thanks
What image are you using on your SOLO4K STB?
PeterAlan
No I do'nt use a wifi dongle. Then what should I change ? ... and where, because I start with BH 1 week ago !
Rgds and thanks
PeterAlan
Sorry for the misunderstanding.
It's not WLAN but LAN, and LAN2... but with 1LAN connector. I try to show you the capture screen tomorrow.
Rgds
