wlan not working, where is save button in wlan settings?
grufti
Hello all,
angel (I hope this short version is allowed) said, 2.0.5A is only possible to get over online connection.
I had no internet connection (only smartphone), so I got a UMTS router (Conrad model for sim card) and set it up (access policy set to no, mac-id-port filtering disabled).
All my active computers are connecting well and access internet, but not the duo2. The computers are Notebook Win7 64bit home, Acer Tablet w. Android 4.1.1, Samsung Galaxy S4 w. Android 4.2.
I set up the Wlan in Duo2.
First problem: Duo2 not always sees my AP and if she sees my AP in AP scanning, sometimes shows it only as hidden SSID (Distance box to router 3 m, other units show AP behind 2 beton walls). Second problem:
with DHCP set to yes I can see the box in the router as DHCP client. It is shown as vuduo2 with a valid IP. But in the wlan status check of the box (german version)
WLAN Verbindung green checked
Funk Netzwerk works endless
DHCP aktiviert green checked
IP Adresse nicht bestätigt red cross
Nameserver nicht bestätigt red cross
is shown.
In DNS window first server is identical to router (ID is shown and is ok) but there is a second server installed (8.8.8.8). Should not come from my router.
With DHCP set to no I can see the box in the router as DHCP client with the old number. But in the wlan status check of the box (german version)
Funk Netzwerk sometimes green checked
DHCP aktiviert red cross
is shown.
But I am not sure, which settings are really active :( , because:
When I leave the settings e.g. Adapter settings, the question 'do you want to leave without saving yes/no' is shown and only 'no' leaves the setup. But there is no possibility (no button) to save the setup. I can leave each Wlan or DNS configuration windows only by 'exit'. If I enter adapter settind again, adapter is set to 'aus' = off.
As long as the 'Wireless Network Configuration' of the box is open, ping to box is succesful. After leaving with exit and 'save = no' (yes only brings me back to 'Wireless Network Configuration' window without saving possibility) ping produces time limit exceeded. If I enter adapter setting again, adapter is set to 'aus' = off.
Could this be my main problem? :wallbash:
Could it be a problem of the german localisation, e.g. a longer german text masks a save button? Is the missing save function my main problem?
If there should be 'save' button, I could try english language bersion.
@angelofsky1980
If you can't put full version 2.0.5A ('strongly recommended to update') on a server, why not change download link of 2.0.5 (not ok) in original thread to 2.0.5A (ok) with a comment. Nobody needs version 2.0.5, if Rev. A is better.
@angelofsky1980
Intermediate revisions are avaiable only online starting from reference version.
@angelofsky1980
thank you for your fast answer . I fear I have to wait for 2.0.6, if my network connection will not work :sad: .
Can you say something to the missing 'save' function?
I changed the language to english after stopping of my recordings and rebooted the box. After this 'adapter settings' showd 'on' initially and IDs at the bottom of the window showed values. Status showed last 2 points checked green. Ping from the Win7 pc worked fine. I tried firmware update and it worked:victory:. Saving of the Wlan adapter configuration is with english language mode not possible, too. Why does connection work now without saving? Wait time, reboot, english language?
Usually the save function into wireless configuration panels is started when the button OK on the RCU is pressed.
Set up your WLAN settings, press OK, press EXIT, confirm "quit without save", and then choose restart network. I did it like this and it worked.
Yes, I did the same too. I cannot find the save button, the instruction seems confused in this network setting section. If there is a button 'save' would be more confortable for many users.
As you know, and the most users knows, we use the green button to save things we change, or we introduce ... so perhaps you have to look to the skins you use. On some screens the button green and the description don´t appear.
The programmers have made a great work ... the skinners too!... Linux receivers are best for testing new things ... Please change your skins ... or test your green remote control key ... and let us know if i am wrong!
beste regards
good testing
